Old Jan 07, 2002, 04:02 PM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
How do I pick the right size prop?
Hey all, is there a genral formula for figuring out what size prop to use for a given wing area ?
I am making a direct drive speed 400 P-51 with a 20" wingspan. About 100 sq inches or so.
JasonJ is offline Find More Posts by JasonJ
Old Jan 07, 2002, 04:26 PM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Jason,
I would think that with that little wing area, though you did not state a weight, but the thing should go pretty fast. Iwould think that you could start out with a CAM or APC 4.75X4.75,5X5, or a 5.5X4.5. Just a guess since those are the props that the pylon guys seem to use.
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Jan 08, 2002, 11:53 AM
JasonJ is offline
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Ok, thanks, Ill start there. The wing span is more like 24 ". Its the P-51 I donwloaded form this site a while ago. Weight will be in the 20 oz range I think. I will use 8 NiMh 1600s with a cheap speed 400 can motor, esc, ele and ali controls. Just playing around with this blue core depron but have no idea about props. I dont want it crazy fast though, dont want to rip the wings off .
Old Jan 08, 2002, 04:06 PM
Megowcoupe is online now
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Umm Jason
I don't want to rain on your parade, but you might want to look at the specs on Jim Ryan's speed 400 planes before you keep going. You seem to have diverged fairly radically from his formula and his planes aren't exactly slow. In fact, there seems to be a certain similarity with what you're coming up with and a pylon racer.
Sam
Megowcoupe is online now Find More Posts by Megowcoupe
Old Jan 08, 2002, 04:24 PM
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
If it's the Python it should have a 29" wing span. Why so small?
Foxtrot is offline Find More Posts by Foxtrot
Old Jan 08, 2002, 04:25 PM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Jason,
Sam's right... you're building a pylon racer. For a scale job, you'll probably want at least 150sq", and you definitely want to keep the weight below 20oz. To give you an idea, the pylon ship I'm working on right now is 100sq" and will weigh about 11oz RTF. You'll never get a S400 scale bird that light, but if you're at more than 18oz I'd strip the gear and try again. 100sq" is very small for S400... it's not enough wing for sport flying... it's really only acceptable for racers.
Your prop should be a 5x5 to start with, or maybe a Master Airscrew 5.5x4. You can try a smaller prop later, but I'd start with a bigger prop to get a little more "pull" on the launch.
Sam (Megow): Have you seen the new Buckaroo DVD? I just picked it up last week... it's sweet!
-David
(Yoyodyne Propulsion Systems)
davidfee is offline Find More Posts by davidfee
Old Jan 08, 2002, 05:02 PM
JasonJ is offline
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
Sorry guys, I dont have the plans or dimentions here to look at so the wing area was a guese, Ill get a better calc on it.
Its not ment to be a pylon racer, but I understand its got a simalar setup and all. I just printed the plans out, cut the templates out and layed em on the foam to get a sorta scaleish look of a P-51. It dose look smallish but we shall see, no big loss if it smashes into the ground, Ill just scale it up and try again. I may make a scaled up fuse to slap on a depron wing I already have made for another jet.
Its going to be a hand or snow launch, so no gear. A set of foam skies maybe .
Discussion How do I pick a prop? wo23dodge Power Systems 15 Apr 15, 2007 10:39 AM
Help! How do I pick a prop? Meko Power Systems 10 May 20, 2006 11:47 AM
How do you mount a 10x6HD prop on a 350C Motor? glenclif GWS (Grand Wing Servo) 9 Sep 21, 2003 07:21 AM
How do you color your prop? sizam Parkflyers 9 Jan 31, 2003 06:23 PM
How do you measure engine/prop thrust? Slow Riser Power Systems 0 Jul 30, 2002 07:19 PM
