Old May 17, 2004, 09:11 PM
malor is offline
Find More Posts by malor
CT,USA
Joined Apr 2004
Question
Need help with servos for DragonFly
Hi guys!
Have had a couple of hard landings (light crashes), nothing broke yet but it seems that my servos are taking a beating. I've had to rebuild the pitch servo once already because it was glitching back-and-forth because the on-center reading was off. It's much better now, but now the roll servo is getting stuck from time-to-time at full left roll. These full left roll "landings" are not helping things.
So my question is, what is a good upgraded servo for my DragonFly?
I think the originals are GWS Naro/Stds.
Would Ball-Bearings servos be better. What about metal gears?
Anyone have some ideas? Recomendations?
Randy.
malor is offline Find More Posts by malor
Old May 17, 2004, 11:35 PM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
I guess the stronger the servos the better...but weight and speed seem to be the important things. You want a server faster than .12 from what I have read.
I am using the GWS PicoBB's About $20US each from Aircraft world. They have served me well so far. (i tape them as well as glued them so there's absolutely no slop in them. With tape only, there's a lot of play)
If you can play with your expo it might help. You shouldln't be doing full left, right up, down anything. (not when you're learning anyway) You need to be more gentle on the sticks. The more stick you give the more you need to correct in the opposite, which normally leads to a pendulum effect..then a crash.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old May 17, 2004, 11:58 PM
EddieNewYork is offline
Find More Posts by EddieNewYork
EddieNewYork's Avatar
Los Angeles, CA
Joined Apr 2004
Hitec HS-55 seem to be a popular choice for micro helis.
EddieNewYork is offline Find More Posts by EddieNewYork
Need help picking servos for 4m Fox surfimp Scale Sailplanes 20 Feb 11, 2005 11:10 AM
Need help with unstable mini dragonfly jug GWS (Grand Wing Servo) 7 Sep 05, 2004 03:55 AM
need help with a towhook for zagi AzJason Foamies (Kits) 6 May 17, 2004 09:21 PM
Need help with parts for TM tenover Parkflyers 27 Feb 17, 2003 07:17 PM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
