Old Jan 07, 2002, 11:43 AM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
True Flaps (is there a easy way)
I have been thinking about ways that you could make "true" flaps for moderate sized (48" WS)RC planes. When I say true I mean someting like a fowler flap set up where the surface not only comes down but also extends aft of the trailing edge producing a more cambered airfoil shape. I think I had too many beers the other night and while I was trying to get to sleep I kept thinking about my new Pond Side with alerons and flaps. I have played with flaperons but do not like how they increase the potential to tip stall and the fact that you lose authority in the roll axis. Anyone THDT before?
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Jan 07, 2002, 11:52 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I know its been done (not by me). You ought to post this in the Scale forum, I'd think you'd get a good answer from some of the pros there.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Jan 07, 2002, 12:34 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I was just the other day browsing thru some pics of how it was engineered. The only drawback was that there were control horns showing from below, but from the top, it looked completely scale - small price to pay for linkages and pivots vs. screws and drive shafts like the real thing! Don't ask me where I saw it, it may have been a magazine, on the web, anywhere.. it has been done, however, so as suggested, the scale guys may be able to help out..
..a
Old Jan 07, 2002, 02:24 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
True Fowler flaps are very difficult to implement on models, especially small ones like the Pondside. The sliding fits must be precise, and of low friction.
A Youngman type, where the flap swings down and aft is a bit more practical and easier to accomplish.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 07, 2002, 02:26 PM
All__talk is offline
Find More Posts by All__talk
Hairy E-Pilot
All__talk's Avatar
Ellensburg, Wa, USA
Joined Dec 2000
This is a basic design I drew up for a 60Ē span Cessna 180 Iím planning, it would use a small flap servo in each wing and all the linkage is hidden. I donít know if the Pondslide wing is thick enough for it though.
Gary
All__talk is offline Find More Posts by All__talk
Old Jan 07, 2002, 11:30 PM
Matt M is offline
Find More Posts by Matt M
Aeronautical nerd
Matt M's Avatar
Seattle
Joined Nov 2001
be sure to seal the gap or you could be in for a pretty wild ride
Matt
Penn State Aerospace '2000
Matt M is offline Find More Posts by Matt M
Old Jan 07, 2002, 11:40 PM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Matt,
Maybe I'm just ignorant, but wouldn't sealing the gap eliminate the intentional slot... and thereby make it an essentially conventional flap, as opposed to a quasi-Fowler flap?
rgds,
David
davidfee is offline Find More Posts by davidfee
Old Jan 07, 2002, 11:47 PM
Hairy E-Pilot
All__talk's Avatar
Ellensburg, Wa, USA
Joined Dec 2000
You want the gap, thats what makes it work better.
Old Jan 08, 2002, 05:13 AM
drewjet is offline
Find More Posts by drewjet
drewjet's Avatar
Central Florida
Joined Oct 2001
As far as being scale the DC-9 and 10 use a hinge point below the wing for their flap. But then they are inferior Douglas products
drewjet is offline Find More Posts by drewjet
Old Jan 08, 2002, 11:23 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
On Gary's flap, I'd move the control horn onto the flap itself, to give some rigidity to the extended flap.
I'm completely another Kadet with flaps, this one a Mr. Mulligan look-alike, with totally concealed operation, using the Direct Aileron Driver type of motion...A wire bent at 45 degrees in the flap that pushes the flap up and down... the inner end is a nose-wheel control horn, pushed directly by a servo..
Like the one on my ideas page on the Earthlink site.
The external hinge does a good job of simulating a Fowler flap.
Old Jan 08, 2002, 12:04 PM
davidfee is offline
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Paul,
How important do you think it would be to round the corner of the flap portion in the transition from the front face to the upper surface? It seems to me that smoothing this transition would allow the air to flow through the slot and stick to the flap better. Any thoughts?
thanks,
David
Old Jan 08, 2002, 03:16 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
David, flaps are for drag for the most part. Finessing the fit when they're up is more important than when they're down.
Old Jan 08, 2002, 03:30 PM
davidfee is offline
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Thanks, Paul... I follow. Makes sense, especially if the flaps are being used mainly for landing. But regardless, there's no room for flaps in my little racers so I guess I don't need to worry about it.
Old Jan 08, 2002, 07:03 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
"Real" Flaps
The easiest flap to tack onto an existing wing is the split flap. Slicing the lower trailing edge skin out and replacing it with a ply flap is dead easy. Hinging is by hinge tape or covering material. For something as small as the Pondside, hard balsa would suffice. Use an elevator joiner/horn for control. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Discussion Is there an easy way to learn inverted tail control ? rcmarty Electric Heli Talk 9 Sep 06, 2006 10:00 PM
Discussion Is there an easy way to measure incidence? mauiguy99 Hand Launch 7 Mar 25, 2006 04:12 PM
Is there an easy way to strenghten Bluecor?? lmopar69 Foamies (Kits) 8 Dec 07, 2005 12:53 PM
Unsticking SoLite...Is there an easy way? mars Parkflyers 3 Mar 06, 2003 12:04 PM
Bowden cable installation: is there an easy way davidleitch Electric Sailplanes 6 Oct 10, 2002 06:39 AM
