Old May 16, 2004, 09:27 PM
yshimoni is offline
Find More Posts by yshimoni
Joined Nov 2003
GWS receivers – Are they worth the money ???
I just up grade to the GWS Formosa and to save some weight I bought the single conversion 6CH GWS receiver (i have Futaba 7C, ch54).
The result is a lighter plane but vary unpredictable. I have many glitches and I feel that it’s un safe to fly.
Any solution for this problem??
Does anyone using the GWS receiver ???
yshimoni is offline Find More Posts by yshimoni
Old May 16, 2004, 10:12 PM
Roger Dorn is offline
Find More Posts by Roger Dorn
Burlington,Wi USA
Joined Jan 2000
In our area they are the one most used.
Roger Dorn is offline Find More Posts by Roger Dorn
Old May 17, 2004, 08:07 AM
Busta Prop is offline
Find More Posts by Busta Prop
Joined Jan 2004
Yshimoni
Dump the GWS and buy a Berg. GWS RXs are fine on flying fields where there is no stray signals but it sounds like this is not the case where you fly. I spent 2 months trying every fix possible to cure interference problems with a GWS RX including relocating all components, twisting all cables, redirecting the antenna, adding ferrite rings and finally wrapping the RX and ESC in enough foil as my wife would have used when cooking the Christmas turkey. Since going to a Berg I have had no problems.
Good Luck
Busta
Busta Prop is offline Find More Posts by Busta Prop
Old May 17, 2004, 10:52 AM
California Condor is offline
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
They are great receivers, most problems are cured by shortning the antenna, they are so sensitive that they pick up lots of interference, cutting off some of the antenna is like turning down the squelce on a CB.
California Condor is offline Find More Posts by California Condor
Old May 17, 2004, 10:55 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
They are OK receivers - when flying alone or with 1 or 2 other users. I never use them at a fly in or other events.
Berg is rock solid, but more $$.
Don't get me wrong - for my slow, and indoor flyers I use GWS for the price you just can't beat them.
Old May 17, 2004, 09:08 PM
yshimoni is offline
Joined Nov 2003
Thanks for replies…
Thanks for replies…
Busta Prop:
Wrapping the RX and ESC in foil and twist the wires will help only if they are causing the problems. If the RX antenna picks up interferences for external source the actual RX design should be improved to filter them out…
But I`m not familiar with “adding ferrite rings”, what are they? How to get them and where to put them??
Old May 19, 2004, 06:51 PM
Joined Jan 2004
Yshimoni - you can get ferrite rings from any radio spares shop. They look like minature donuts and you loop servo leads and ESC leads through them a few times. Long untwisted leads can act as antennas themselves and these ferrite rings stop the signals being fed back to your rx. Search forums like this one and you will find people who swear by them.
On the foil issue, you are right that foil can suppress onboard sources interference but in the same way it can shield components from external interference - and more important it was a cheap test before I went out to buy a new rx.
I hope you fix your problem.
Happy flying - Busta
GWS B2 - Are they worth it? yogorilla Parkflyers 5 Apr 03, 2005 10:13 AM
LI-ION PRISMATIC CELL are they worth a try gtstubbs Batteries and Chargers 4 Aug 17, 2003 03:07 PM
What are these?? What are they worth?? Gary Morris Aircraft - Electric - Airplanes (FS/W) 14 Feb 15, 2003 06:57 PM
Graupner Fans - Are they worth it? kennypinkerton Electric Ducted Fan Jet Talk 0 Jan 13, 2003 08:04 PM
glo to electric conversions, are they worth trying? Aubrey Electric Heli Talk 6 Feb 27, 2002 10:04 PM
