Old May 15, 2004, 04:27 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Is it my Rx or Tx?
1. Several times now, on plugging in the battery of my Unicorn, the ESC starts beeping like mad. I then unplug the battery, and unplug both sercos and ESC, plug it all in again, and most of the time everything is fine again.
2. Last week I was flying my Unicorn, and out of the blue lost total control and crashed. The two other pilots in the field where on total different frequencies. Upon retrieval there was minimal damage to my 'Corn, but the antenna plug had come loose. I am not sure if this was cause or result. I soldered the plug back on, and had a few normal flights. During the last flight suddenly my 'Corn lurched all over the sky for no apparent reason for a few seconds, and then was a docile as usual. I landed, and while walking back to the car with both Tx and Rx still switched on, the servos suddenly started a life of their own! I assumed someone, somewhere was on my frequency.
3. Yesterday I was flying my Unicorn again, and out of the blue again lost total control and crashed. Upon retrieval while still lying in the position I had found it, no input from my Tx would cause the servos to move. I picked up my 'Corn and started walking back to the car. Again the servos started a life of their own. According to the frequency board I was the only one using Ch60. I asked around, and no-one fessed up being on Ch60. I unplugged the Rx, and found all in order. Plugged everything back in. A few times I had to repeat this (see #1) untill I had armed the ESC properly. I walked onto the runway to launch my 'Corn, when again the servos and the motor started a life all of their own.
Any ideas anyone?
Up&Away is offline Find More Posts by Up&Away
Old May 15, 2004, 04:40 PM
Gliderguy is offline
Find More Posts by Gliderguy
An Original!
Joined Aug 2001
I have heard of a guy having a similar problem caused by the wire going to the antenna inside the case breaking loose. You might check that wire just for security sake. In cases like this it sure would be nice to have a channel checker just to be sure it isn't some out of area interference.
Gliderguy is offline Find More Posts by Gliderguy
Old May 16, 2004, 04:13 AM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
To debug it, then just try a different receiver. I must have one for you to try out, and therefore see if this is the problem.
If confirmed, then it will be easier to single out the issue.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old May 16, 2004, 04:26 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
There's an idea. Why didn't I think of that ? I have a brand new 6 channel Rx for my Filip. It won't fit in my 'Corn, so I can't fly with it, but I can plug it in to see if I have any problem arming the ESC.
The only problem will be that my wife will see my new Rx...
Old May 16, 2004, 04:18 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Well, plugged in my regular Rx, armed the ESC no problem!
What now?
Old May 16, 2004, 05:10 PM
Joined Sep 2001
It is possible that crashes, damaged the receiver.
My 2 agurot, send it for repair to the place you bought it and don't use it for now.
Old May 16, 2004, 06:38 PM
An Original!
Joined Aug 2001
You might also try a new or different crystal in your problemed Rx. Crystals do go bad as well.
Old May 17, 2004, 01:54 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I'm not totally convinced (yet) that it is the problem is with the Rx. I was going to take my Tx in for servicing anyway, before doing the maiden with my Filip 600 Sport. So we'll see. I can do that through my LHS. The Rx has to be serviced in the US.
Discussion Lost control of plane, is this a Rx or Tx problem? craddojc Electric Plane Talk 15 Nov 16, 2006 05:45 PM
Wanted JR Receiver + JR crystals for rx or tx, (72MHzFM) sportytourer Aircraft - General - Radio Equipment (FS/W) 2 Jun 25, 2006 04:43 PM
Help! My Aero Ace RX or Tx has gone wacky. seric Scratchbuilt Indoor and Micro Models 4 Apr 27, 2006 10:41 AM
Discussion Rx or Tx not working ? digsy Beginner Training Area (Aircraft-Electric) 9 Jan 13, 2006 06:25 PM
RX or TX Poblems? ExploreR Radios 8 Apr 09, 2004 06:08 PM
