Well, I just finished over the weekend the one I bought from the WRAM show (Sorry I took too long Dave!!!
This one is full house(!!!) with the following setup:
Sky Hooks and Riggings RX/ESC Hybrid
2 WesTec 3g servos (Rudder and Elevator)
GWS BP101 servo (Aileron)
Dual N20 gear drive, 4.2:1 gearing, wired in series
Gunther 5" prop
3-cell 250mah LiPoly pack
Landing Gear and Tail Skid (Sorry again Dave!!!)
3.4oz AUW
Building was a snap. I did most of it while watching TV. Dave sure was right when he said it could be built on one's lap (well almost, in my case anyway). This was also my first ever Solite covering job. As such, it took me quite a while to cover this thing.
The dual N20 drive provides adequate power. Takeoff run was several feet. But, my setup is a bit tail heavy (CG was just behind the 1/4" rear of the spar limit as given in the instructions) and as such was very pitch sensitive. I also experienced some glitches with the RX/ESC Hybrid. As such, I still haven't flown it much other than a few runs to test takeoff and landing characteristics. I guess I have some rearranging to do. Even with the geared drive, it also might be a bit too hot for my 3-court flying area. My next sortie should determine that.
In any case, this thing is tough. I have dorked this plane into concrete twice (radio glitch) and worst damage was 2 cracks on the wing leading edge. The light weight and magnet wing hold must have prevented this thing from turning into a pile of toothpicks.
My intent was to initially turn this thing into a sport flyer instead of the intended little speed demon. I figured that at 88 sq.in., It should do just as well (if not better) as the DJAerotech Roadkills in the same weight range.
If all goes well, I will then configure it with a dual N20 setup that produces around 4oz of thrust on 3 LiPoly cells. That should put the rudder into better use.
Jun Nolasco
