Old May 14, 2004, 01:39 AM
Propjob81 is offline
Find More Posts by Propjob81
Propjob81's Avatar
Joined Apr 2004
Smallest EDF jet?
I did a few searches and found some micro model pushers, but couldn't find what I was looking for... What is the smallest EDF that anyone has built? There's got to be an edf 40 F-18, or maybe a 30mm EDF F-14. Does anyone know of any sites? Or Pictures?
Propjob81 is offline Find More Posts by Propjob81
Old May 14, 2004, 03:10 AM
Ado is offline
Ado
Find More Posts by Ado
Ado
Meow?
Ado's Avatar
Brisbane Intl, Australia
Joined Sep 2001
Smallest EDF I have seen are the small "zagi" style wings with the edf 50's on then. True jet like plane is the F-4 Phantom with the twin EDF-50(?) in it.
Can remember the brands etc... but a couple searches on Ezone will come up with some answers.
Cheers,
Ado
Ado is offline Find More Posts by Ado
Old May 14, 2004, 11:05 AM
Propjob81's Avatar
Joined Apr 2004
The reason I'm asking is because I have this F-14 guillows kit and I'm thinking about attempting a micro EDF design with it. Possibly with retracts and wing sweep. Controlled by tailerons. I took some measurements, The EDF will have to be about 33mm OD and put out no less than 25g of static thrust.
Old May 14, 2004, 11:27 AM
Propjob81's Avatar
Joined Apr 2004
1", 25mm EDF with plenty of thrust!
This is the kind of stuff I'm looking for... http://www.rcgroups.com/forums/showt...8&page=1&pp=15
Old May 15, 2004, 11:37 PM
Propjob81's Avatar
Joined Apr 2004
Maybe my ideas are a little beyond modern technology, but I don't think it will be too long before this is possible. Maybe not a guillows kit, but atleast one that is the same size: Approximately a 1:40 scale model.
Old May 16, 2004, 12:13 PM
Cyberman is offline
Find More Posts by Cyberman
Mad Max meets the Thinker
Cyberman's Avatar
Pittsburgh, PA
Joined Apr 2004
GWS makes an EDF30 sized unit that's labeled TBA stats published are:
Code:
Model		Voltage	Current	g	oz	Watts
EDF1220x6	7.2	0.6 	13	.46 	4.32
EDF1220x6	8.4	0.8 	16	0.56	6.72
EDF1220x6 	9.6 	1.0	21	0.74	9.60
I suspect one would have to use some tiny batteries on these and push the motors hard. In any case you would want to keep things ultra light
I don't think you could use rewound CDROM motors to power one of these either (motor is too large in diameter).
Cyb/Stephen
Cyberman is offline Find More Posts by Cyberman
Old May 16, 2004, 01:26 PM
Propjob81's Avatar
Joined Apr 2004
Does anyone know when it is going to be sold, or where I could buy one right now? at officeshops.com they sell them, but it says "coming soon TBA"
Old May 16, 2004, 04:23 PM
meowmix is offline
Find More Posts by meowmix
You will be assimilated!
Caslte Rock, Colorado
Joined Apr 2004
I'm working on an EDF jet. Uses 40mm fan unit, 30 cm wingspan
It might be kit-afied
meowmix is offline Find More Posts by meowmix
Old May 16, 2004, 04:34 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
My F-35 isn't that small but at 24 inches long with a 19.5 inch wingspan and over 200 watts of power it shows that the technology is there. 50mm fan
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 16, 2004, 05:47 PM
meowmix is offline
Joined Apr 2004
That's a really nice one! Looks like the Air Force version. Your own build or a kit?
Old May 16, 2004, 07:44 PM
Kevin Cox's Avatar
Joined Jan 1997
Thanks.
It is my own.
http://www.rcgroups.com/forums/showt...&highlight=F35
Old May 16, 2004, 08:09 PM
meowmix is offline
Joined Apr 2004
Wow. Hey, on my design it is a single swept-back wing with an airfoil (double thick 1/8 inch foam sanded), but I can't figure out a good air scoop design. Any hints?
Old May 16, 2004, 09:16 PM
Kevin Cox's Avatar
Joined Jan 1997
Meowmix,
I chickened out with the flat plate wing and cut wings with an airfoil. By "scoop" do you mean intake for the fan?
Old May 16, 2004, 09:40 PM
Propjob81's Avatar
Joined Apr 2004
That F-35 is awesome!
Old May 16, 2004, 09:46 PM
Propjob81's Avatar
Joined Apr 2004
That's pretty small, but do you think that a smaller version is possible? Maybe a 75% version with an 18" wing.
GWS EDF Jet Trainer flies! steve neill Electric Ducted Fan Jet Talk 61 Jul 02, 2010 01:39 AM
New EDF Jet Pics KillerCut Electric Ducted Fan Jet Talk 0 Feb 02, 2002 11:29 AM
Recommend an EDF jet kit... TedLarson Electric Ducted Fan Jet Talk 5 Nov 25, 2001 12:50 PM
Recommendation for 1st EDF Jet? HardAbz Electric Ducted Fan Jet Talk 14 Aug 08, 2001 12:06 AM
best edf jet to start with ? exowatt Electric Ducted Fan Jet Talk 19 May 04, 2001 12:39 AM
