Old Jan 06, 2002, 09:20 AM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Need help with chooseing retractable landing gear.
I'm building 2 planes.Both call for retracts. one plane is 57"w.s. and the other is 54"w.s. they should be about 5lbs each.i never had experiance with retracts either.Which is better mechanical or air? Which company is best to deal with?thanxs for any help.stefanP
Ghost rider requesting a fly by.......
KOMET 44 is offline Find More Posts by KOMET 44
Old Jan 06, 2002, 09:37 AM
Dorme is offline
Find More Posts by Dorme
Dorme's Avatar
United States, NJ, Manchester Township
Joined Dec 2000
I strongly recommend air vs. mechanical, as air is more reliable. The setup for mechanical is time consuming and then one bad landing and they are jammed. Although mechanical are cheaper by far, air retracts will operate more smoothly and give you more flying time(less repairs).
For companies, I use Spring Air and Robart. Spring Air makes a very small air retract and you can talk to the man who makes them if you need a special job done. Robart also makes very good retracts and are used by quite a few master builders and flyers.
I have used both mech. and air with mech. having more of my vocabulary put to use!
Dorme is offline Find More Posts by Dorme
need help with PBY landing gear jeff262 Scale Kit/Scratch Built 14 Apr 10, 2005 09:09 PM
Need help with Microbat or Too Cool Bipe landing gear rcmann Foamies (Kits) 2 Mar 20, 2005 01:25 AM
Help with Dandy Sport Landing gear jbshocks Parkflyers 6 Sep 21, 2004 11:26 AM
Question Need Help Designing & Making Landing Gear Buzz_Man Foamies (Kits) 8 Aug 30, 2004 02:36 PM
Need help with landing gear MaxxTrip Beginner Training Area (Aircraft-Electric) 1 Mar 05, 2004 11:10 PM
