Old May 12, 2004, 01:48 AM
Bocan is offline
Find More Posts by Bocan
Joined May 2004
Corrugated plastic model
Have anyone tried to construct a model from corrugated plastic sheets? They are low cost and easily glued together to create hollow sections with cross walls. I plan to make one but wonder if anyone have already done it.
Bocan is offline Find More Posts by Bocan
Old May 12, 2004, 02:19 AM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
Coroplast is a common material.
JKA uses a lot for tails and doublers (Big-T for example).
Search for SPAD - gas combat aircraft - they are a scream to watch when they get into a real fur ball out there!
I think maybe AeroCore makes planes out of it but they are a bit heavy for electric use.
Crash
crashsiegel is offline Find More Posts by crashsiegel
Old May 12, 2004, 02:57 AM
schoey is offline
Find More Posts by schoey
schoey's Avatar
Newcastle, Australia
Joined Nov 2000
Heres mine, not quite a beginner model its a mugi ( www.mugi.co.uk ) from memory.
While coroplast/corflute/correx is very strong, it is heavy in comparison to foam. Correx seems to have been forgotten now with fanfold and depron being the new 'cheap' airframe material.
Grant
schoey is offline Find More Posts by schoey
Old May 12, 2004, 10:19 AM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
www.spadtothebone.com Coro is not all that heavy for large wings compared to foam.
rutat is offline Find More Posts by rutat
Old May 12, 2004, 11:21 AM
Quicker is offline
Find More Posts by Quicker
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
http://spadworld.net/index.php has a good electric section, and a good foamie section. Most of the foamies have been glow powered, but the electric section has come up with some cool stuff.
Quicker is offline Find More Posts by Quicker
Old May 12, 2004, 08:43 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Matter of fact, we have a forum specifically for that kind of construction!
Off to the S.P.A.D. forum.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jan 13, 2013, 02:02 AM
himansu.tutu is offline
Find More Posts by himansu.tutu
India, OD, Bhubaneswar
Joined Dec 2012
i am tring my level best to make a coro plastic model but i am unable to make a wing of perfect dimension. several time while turing the upper part of the coro plastic during making wing the upper surface of wing gets folded in many places. how to avoid this prob and make a perfect one?
himansu.tutu is offline Find More Posts by himansu.tutu
Old Jan 13, 2013, 09:39 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Did you score the leading edge where the fold should be? A screen installation roller or phillips screwdriver is commonly used. and folded over the table edge or o fixture of some sort.
aspeed is offline Find More Posts by aspeed
Old Jan 14, 2013, 10:12 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
And what thickness of coro are you using? If 2mm, I score it with a screwdriver and fold it over a table edge. If it's 4mm, I route out a 3/8" groove with my Dremel tool with router attachment leaving just the outer skin. That lets it fold over perfectly straight and takes a LOT of tension off the glue joints.
JohnsPop is offline Find More Posts by JohnsPop
Old Jan 17, 2013, 01:59 AM
Rusty Nail is online now
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Traditionally the flutes run from leading to trailing edge. If you are trying to make a wing with span-wise flutes you need ribs or a wide foam support at the foils thickest part.
Rusty Nail is online now Find More Posts by Rusty Nail
Old Jan 26, 2013, 11:38 AM
paintmann111 is offline
Find More Posts by paintmann111
United States, CT, Old Lyme
Joined Sep 2011
edit
paintmann111 is offline Find More Posts by paintmann111
Old Jan 26, 2013, 12:18 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
This is incorrect ^ (Sorry but we have to set the record straight for the new guy working with coro here.) Having built with flutes running exclusively chordwise (front to back) I have never had a folding problem in turns. In fact I do extremely high G loops with a narrow chord, long span combat plane built from all coro in my avatar pic you see here. (I do have to pay attention to using a good joiner to bring both halves together though.)
In fact running the flutes spanwise will give creasing problems along the flutes leaving a less then desired airfoil without additional support like Rusty Nail said above.
Notice the pipe direction (flutes) in the pic below. Nothing but yard stick material for a wing spar.
Mig Man is offline Find More Posts by Mig Man
Old Jan 26, 2013, 05:53 PM
Rusty
Rusty Nail's Avatar
Joined Feb 2006
Paintmann, I have done spanwise wing construction for reasons of structure but more for an accurate foil.
It makes a very strong wing in span and in torsion, as with a tapered wing the flutes run at opposing angles top and bottom.
Ribs take more trouble and the SPAD ethos is quick and dirty, and they fly well with strange foils.
I think it is worth experimenting with a correctly chosen compressible wide foam 'spar web' ar la 'Armin' wing. I have done this a long time ago and still got a small kink in the 3.3mm 1 metre wing upper skin. I think heating the sheet before bending and closing, maybe with a powerful hairdryer, will help on the small cord wings with a more pronounced curve. Some form of oven heat treating and molding over a form, like some foam wings, would be ultimate, but not very SPAD like! You could try using the bed of a foam cut wing as a mold...
Let us hear from other spanwise builders.
Old Jan 26, 2013, 07:11 PM
MrClean is offline
Find More Posts by MrClean
Somewhere near Parkville, Mo.
Joined May 2004
My first 25 size combat ships were the SPAD Defenders with spanwise flutes of 4 mil. Worked great.
Most of my current ships use chordwise all 2 mil flutes or a mixture of spanwise 4 mil with 2 mil upper surface chordwise.
al la Armin, heck, I'd say we' designed it first but tha'ts too simplistic an answer as I'm sure someone was doing it before either of our groups were. We once ran into a guy in florida that was building coroplast airplanes that really close resembled SPADs but he knew nothing of us. Similar minds think alike. The important thing though is to remmeber Hobbico owns the rights to any kind of model airplane part construction with coroplast. They bought it from Aircore who developed it in the 70's after Coroplast came out. So really, any innovations probably should be credited to them. The SPAD guys just wanted to build an in-expensive combat model and there were all these "free" campaign signs at the side of the road.
By the way, the genisis of this zombie thread was in May of 2004 and was resurrected 8 days ago, 9 years later. SPADS are gosh, circa 97 or 98. I'd have to dig up the year, but either 14 or 15 years old now, maybe 16. I started flying them a year after they got on the internet on Wichitas combat forum.
MrClean is offline Find More Posts by MrClean
Old Jan 27, 2013, 02:01 AM
Spaderman is offline
Find More Posts by Spaderman
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
Hello,
Agree with you, for my models, I use 2 methods and I think 2 are substantially stronger.
With some details, for flutes in the spanwise, I use 4mm and flutes in the direction of the cord, I use 3mm
But I also think that the second method is more aerodynamic, simply just a little more work ....
After many models and many crashes, I found that the repairs on the wings with flutes in the direction of the cord is more difficult, because in shock at the leading edge of the wing, the coro will cleave quite easily.
Spaderman is offline Find More Posts by Spaderman
Plastic Model Conversion Parknfly Parkflyers 23 Jun 18, 2004 08:58 PM
Aftermarket Plastic model decal site? dpoles Scale Kit/Scratch Built 16 Mar 17, 2004 02:19 PM
Good Plastic Model to work from? Jim Miller Scale Kit/Scratch Built 8 Dec 24, 2003 08:46 AM
plastic model manufacturers petn7 Life, The Universe, and Politics 9 Nov 05, 2003 08:04 PM
Scale, Static plastic model kits, recommendations? Looooeeee! Life, The Universe, and Politics 13 Oct 07, 2002 08:29 PM
