Old Jan 06, 2002, 08:12 AM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
Totally bizare. When I run my radio/plane in my basement it glitches outside it's ok
Yesterday I was trimming out my new TM in the basement of
my house. I was getting glitches and receiver lock ups every few
minutes. This is my first RC plane so I have never tried this before. But my RC cars don't have any problems.
Got really frustrated and went outside did a range check with the antenna down now it works perfectly even flew
it around the front of my house (antenna up).
Take it back down in the basement and whammo lockups with the antenna up or down.
If I use the radio and a FMS interface cable it works fine in the software.
I am using gws 4p receiver and flight pack with hitec eclipse 7
tx on channel 47.
One thing to mention. In my basement I am running.
TV, 1 large computer server, 1 fast gaming machine, overhead florescent lights....other assorted printers scanners and such.
Anyone seen this type of thing before.
The Other Dave is offline Find More Posts by The Other Dave
Old Jan 06, 2002, 08:38 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
You already know what the cause is: All the computer gear! Jürgen
P.S.: You can check it with a world-radio-receiver too.
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 06, 2002, 10:22 AM
jkolp is offline
Find More Posts by jkolp
Lynn In
Joined Dec 2001
you might be to close to the rec with the transmitter thus over driving the receiver try moving the radio away from the model it might help
Good Luck
jkolp is offline Find More Posts by jkolp
Old Jan 06, 2002, 10:28 AM
Joined Nov 2001
Update
Ok went out to fly this morning. Very cold 10 F or so.
Bad bad bad.
Plane started glitching in flight after good range check.
Crash.
Picked it up all looks ok.
Unplug and plug in bat.
Servos full travel and hang.
Reset both tx and rx plug it in same deal.
I definitely think this is a rx problem due to the fact that when it dies it cannot be reset by turning off and on tx.
How close are people running their esc to the rx. Mine is very
close.
One other thing. Even while running the am-sci li-ions I am using
are outputting 8.2 volts. The esc should be ok with this but
it just seems strange.
TIA Dave
Old Jan 06, 2002, 11:13 AM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
bad conection
It could be a bad "crimped" connector and that vibrations couse it to fail.
Inspect each single pin and do range checks with running motor.
cmulder is offline Find More Posts by cmulder
Old Jan 08, 2002, 11:25 PM
Terry W is offline
Find More Posts by Terry W
Pittsburgh PA.
Joined Dec 2001
Dave
The florescent lights will do that too. Happens
at my house and my friends house to. Don't know
if its the lights or the reflectors around the lights.
I guess you could turn out the lights and try it.
but its really hard to fly these little suckers in the dark.
Terry W
Terry W is offline Find More Posts by Terry W
Old Jan 09, 2002, 11:31 AM
flyfalcons is offline
Find More Posts by flyfalcons
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
crystal
I had the same glitching problem when first setting up my TM gear. The servos would give FULL (more than tx-capable) travel and hang up. Turned out if I pushed the crystal in one direction, the whole system would go bonkers. Pushing it back in the other direction solved the problem completely. I rigged it to stay that way but it's disconcerting knowing my model's controllability is just hanging on a thread.
flyfalcons is offline Find More Posts by flyfalcons
Question Can I put a reall radio systyem in my park zone/esc,servos. cobrapilot Electric Plane Talk 4 Aug 14, 2005 05:28 PM
Can I bring my RC plane & radio equipment on board a commerical airliner???? atsiang Electric Plane Talk 15 Mar 27, 2005 01:15 PM
MM Dandy, newest plane in my hanger 10Thumbs Parkflyers 12 Mar 10, 2003 09:20 AM
AM radio static in my pickup Al P Life, The Universe, and Politics 11 Mar 16, 2002 07:04 AM
Vote my new aerobatic plane in... kepople Electric Plane Talk 11 Jul 30, 2001 03:24 AM
