Old May 11, 2004, 01:18 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
The VTO - A vertical takeoff 3D parkflyer by Jetset44 V2
Part 2 time! Here's part 1:
http://www.rcgroups.com/forums/showt...0&page=1&pp=50
Carry on
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old May 11, 2004, 01:27 AM
jetset44 is online now
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Part 2?!? Well heck, I never would have thought this thread would get that far...COOL!!
By the way GKN, were you running that EDF-50 motor with A gearing?
Steve
jetset44 is online now Find More Posts by jetset44
Old May 11, 2004, 02:08 AM
Flyingwing is offline
Find More Posts by Flyingwing
Just my 25 cents.
Flyingwing's Avatar
Escondido, CA
Joined Sep 2003
congrats to jetset44 for a great plane and a great thread!!!!!
Flyingwing is offline Find More Posts by Flyingwing
Old May 11, 2004, 05:30 AM
GKP27 is offline
Find More Posts by GKP27
GKP27's Avatar
Middlesex, New Jersey (excl EWR), United States
Joined Jan 2003
Steve
JETSET
No, C gearing, A gearing would be to high of an amp draw. I want to try a D or E gear with 11 and 12in. props mite be interesting, maybe get 9 or 10oz. out of it.
GKP27 is offline Find More Posts by GKP27
Old May 11, 2004, 09:36 AM
Wayno-san is offline
Find More Posts by Wayno-san
From the bowels of MI
Joined Apr 2004
Jetset44,
You're right, that's what the control line is made out of , Decron. Looks like I'll have to keep looking for stiffer thread. I did ask at my LHS and sporting good stores for the either Kevlar or Spectra thread, but so far no dice. I'm going to stop by another shop today to a take a look. Thanks for the help and I'll let you know how it goes once I get the PP switched over.
Kevin,
Any chance you could post a tight closeup of your PP control horn setup? Thanks!
Wayno-san is offline Find More Posts by Wayno-san
Old May 13, 2004, 01:31 PM
Joined Apr 2004
Has anyone tried the twin IPS setup with a Bluecor Mini-VTO? I was looking at the specs on this unit and the power/weight ratio is better than the single motor unit. In particular, I'm looking at the 7.2V Twin C Power System (IPSD-RXC-CS) which can produce up to 267g of thrust. That should make it hover! Let me know what you think.
Old May 13, 2004, 02:03 PM
tnkenyon is offline
Find More Posts by tnkenyon
Lexington, KY
Joined Aug 2003
Look back in the previous thread - I write about mine which is 26" ws using a dualB and 12x6, hovers at 7.5oz AUW
tnkenyon is offline Find More Posts by tnkenyon
Old May 13, 2004, 02:10 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Good thought. But the Twin IPS is quite a bit heavier than the standard IPS (1.7 oz versus 1.0 oz) and requires a heavier battery (1.5 oz versus .75 oz), so you would want to scale the Mini VTO up to keep the wing loading down. My design goal for VTO-type ships is 2.5 oz/ft2 as a maximum wing loading, and this combination would push the Mini VTO wing loading up to 3.6 oz/ft2.
I ran some quick numbers in my VTO sizing spreadsheet and found that the Twin IPS would work best with a 26" span Bluecore VTO. That would give you a wing area of 450 sq in, a RTF weight of 7.9 oz, and a wing loading of 2.5 oz/ft2. With 267 g (9.5 oz) of thrust, it would hover easily. Note that's about halfway in size between the 20" span Mini VTO and the 30" span VTO, which is what you'd expect (since the EPS-350C in the VTO weighs 2.2 oz). Just scale the VTO or Mini VTO plans to to 26" span and it should work well. Let us know how it works if you do!
Steve
Old May 13, 2004, 08:48 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Just 'cause I'm crazy, here's what I tried tonite:
28" span
3ch
Eps 350 D gear
14" GWS prop
Etec 2S 1200
Sure, the motor got a little warm, but what fun! It's the torque-rolling king.
blucor basher is offline Find More Posts by blucor basher
Old May 13, 2004, 09:43 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
Hey guys
I have manually by hand scaled up the VTO. It's the big version and i was wondeering if i could use the current equipment in my e starter on it:
3x naro's
6 ch naro
ics 100
EPS 300 with c gearing and a 10x8 GWS prop
Two cell e tec 1200 lipo
Will this work out well?
Also instead of using depron or FFF, can i use x-acto foam board? It's a foam board sanwiched between two layers of cardboard. will this work out with some wood/carbon strengthing spars?
Will i hover with this setup? (:
tommyeflight89 is offline Find More Posts by tommyeflight89
Old May 14, 2004, 12:04 PM
tnkenyon is offline
Lexington, KY
Joined Aug 2003
you will probably need a D gear and a 12x6 prop to get it to hover. It'll fly w/ your setup, but doubt it will hover. I think the foam board will work if you remove the cardboard.
Old May 14, 2004, 01:36 PM
ARF Hater Club
Toronto, Ontario
Joined May 2004
Thanks tnkenyon (:
Old May 16, 2004, 06:48 PM
GNuse is offline
Find More Posts by GNuse
Georgia
Joined Oct 2003
I have found a major flaw with the VTO. It absolutely ruins the feel for one's other aircraft. I have had to park my other aircraft until the VTO either destroys itself (it has tried, but the thing has so much maneauverability that even I could save it. It has plenty of power for vertical flight..........yuuch, most other planes just don't cut it these days. Did I mention this thing is really great fun........oh, and the secret for truly novice hovering, is dental floss. Stake it to the ground, add power and amaze the world
GNuse is offline Find More Posts by GNuse
Old May 16, 2004, 06:56 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Cool! Glad to hear you're enjoying it. You know, I'm having the same problem--all my other RC models just pale in comparison in terms of fun factor to the VTO. I even built a new Edge 540 ShockFlyer a few weeks ago with an Axi 2208 brushless, and while I like it a lot, I still like flying the VTO better! For those of us that live for low, slow, wild, and in-your-face kind of flying, the VTO is perfect!
Steve
Old May 17, 2004, 12:03 AM
Joined Jun 2003
Lovin' the VTO
I've cut down to just two planes. The BL Slow stick and the VTO. Between these two, I can do anything I want. I still want to buy a radio with expo and stuff for the VTO, but I'm doing fine with the cheapie. I mostly fly it now on Kokam 340 2s Lipos. Awesome vertical, and still get 8-10 min flites if I'm careful. This is airframe #6, I think I've finally got exactly what I want. I took one inch off the span, and added two inches to the overall length. I don't use any fuselage below the wing anymore. I mount the servos at the back and use very short open carbon pushrods. My favorite plane!
The VTO - A vertical takeoff 3D parkflyer by Jetset44 V3 Martin Hunter 3D Flying 458 Mar 05, 2013 09:06 PM
Discussion Question - Power System for The VTO - by Jetset44 andrewwells13 Foamies (Scratchbuilt) 0 Nov 20, 2006 08:46 AM
Question Power System for The VTO - by Jetset44 andrewwells13 3D Flying 0 Nov 18, 2006 01:53 PM
The VTO - A vertical takeoff 3D parkflyer jetset44 3D Flying 591 May 11, 2004 01:19 AM
What is vertical performance and 3D ? ARE Beginner Training Area (Aircraft-Electric) 6 Dec 01, 2001 11:24 PM
