Old May 10, 2004, 10:13 AM
kaja is offline
Find More Posts by kaja
munich/germany
Joined Apr 2003
gliding/climbing time ratio
It will be very interesting to know this ratio, sure without thermal. We can than compare how good are our ornis. Can somebody give values? The more gliding for the same climbing the better.
Regards Karel
kaja is offline Find More Posts by kaja
Old May 14, 2004, 09:27 PM
wmueller10 is offline
Find More Posts by wmueller10
Seale, AL
Joined Oct 2003
wmueller10 is offline Find More Posts by wmueller10
Old May 15, 2004, 03:31 AM
kaja is offline
munich/germany
Joined Apr 2003
Thank you Willi. Can you give me times for climbing and gliding?
Karel
Old May 16, 2004, 11:27 AM
kaja is offline
munich/germany
Joined Apr 2003
hello Willi,
today i maked first simple mesurement. For 30sec climbing my bird maked total time 70-80sec by full accu 2x E-Tec 1200. After about 6min accu will be tired and it climbes not so good. I need 12A for full power. Probably it is too much for these accu, but i have no better ones. Gliding ratio i can only guess for moment. about 6:1. EPP wing will be better than my styro, it brakes easily.
Regards Karel
Old May 16, 2004, 10:36 PM
Seale, AL
Joined Oct 2003
Old May 17, 2004, 02:41 AM
kaja is offline
munich/germany
Joined Apr 2003
Willi,
i can not use 3x E-Tec but i use new ones, HP types. My total flying time is about 14 min. My bird soared very good, i use every thermal wind. Karel
Old May 17, 2004, 07:29 AM
Seale, AL
Joined Oct 2003
Old May 17, 2004, 11:19 AM
kaja is offline
munich/germany
Joined Apr 2003
Yes Willi, it is. It glides probably better then 6:1 because it is wing with normal profil. I mean only that EPP will be better than styro, but styro works also. Now i fly with normal tail, see
http://www.rcgroups.com/forums/showt...44#post2142944
Karel
Old May 17, 2004, 01:22 PM
Seale, AL
Joined Oct 2003
Old May 17, 2004, 03:29 PM
kaja is offline
munich/germany
Joined Apr 2003
Willi,
CG is 45% of chord in midde of wing. My locking system is very sophisticated, with PIC-processor and 3 hallsensors and almost the same locking mechanics as PH. But it works also not 100%. I think one must catch the wing i.e. supplementary stop with block & servo. Karel
Old May 18, 2004, 11:56 AM
Seale, AL
Joined Oct 2003
Old May 18, 2004, 02:23 PM
FrancisG is offline
Find More Posts by FrancisG
FrancisG's Avatar
Dijon. France
Joined Nov 2002
I have a modified glide lock on my Slow Parrot, it works 90% or better
Willi,
What's new on your glide lock?
Francis
FrancisG is offline Find More Posts by FrancisG
Old May 18, 2004, 03:22 PM
kaja is offline
munich/germany
Joined Apr 2003
Willi,
i have no video yet with my styro. My bird flappt +-30. I have the same question to you as Francis. Can you put picture?
Karel
Old May 18, 2004, 04:57 PM
Seale, AL
Joined Oct 2003
Last edited by wmueller10; Nov 04, 2007 at 07:57 AM. Reason: removed 100% catch rate statement
Old May 19, 2004, 01:54 AM
FrancisG is offline
FrancisG's Avatar
Dijon. France
Joined Nov 2002
I'm sure both of you have seen my thread
Effectively! Thanks, Willi.
Francis
