Old Jan 05, 2002, 11:34 AM
Dandi6065 is offline
Find More Posts by Dandi6065
DAve caNDI,& 5#'s of fury
Dandi6065's Avatar
Oscoda, MI :)
Joined Jan 2001
OK I have had it with balsa- Help me to become a foamie nut
Ok I have had it with cutting out ribs, bulkheads, and the other assorted balsa building requirements. Having viewed the Foamie forum bash and looking at the planes ,I must become a foamie nut.
What type of building materals, and where to buy them.
Glues?
Mainly I need to know what coroplast is and where to get it?
What is Depron?
How to make a hot wire cutter?
I have to build foamie planes, as I tend to crash a lot
Thanks all
Dandi6065 is offline Find More Posts by Dandi6065
Old Jan 05, 2002, 11:52 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
The answers to many of your questions can be found using the search function. They have all been answered many times before.
The biggest advantage of foam is in the new generation of ARFs. Simple inexpensive designs can now be made with all shapes and sizes...but....to do these designs from scratch is no advantage over making them in balsa. Both techniques require skill, planning, and plenty of patience.
If you are an impatient or unsatisfied modeler then maybe you need to purchase a few of these ARF designs and improve your flying skills first. I have become an excellent flyer using ARFs and now spend more time modeling because I now have the confidence to build, test, and fly scratch built designs without seeing them "re-kitted" after the maiden voyage.
Corroplast is corragated plastic. It looks like shipping box material but is made from plastic instead of cardboard.
Depron is often used as a food container like a BK Whooper box or when you take home food from a resturant.
If you crash often...do yourself a favor and buy a Zagi and a Tipsy. The Zagi pretty much laughs at most crashes and a Tipsy is virtually impossible to stall.
Regards.
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 05, 2002, 02:01 PM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Dan,
I hear ya'. Balsa can be frustrating, especially after a crash! Doesn't hold up very well, does it?
Depron is extremely thin, light weight foam. Folks generally heat it slightly with a heat gun (or blow dryer), then "mold" or bend a leading edge into it. You end up with an undercambered airfoil like the GWS planes.
Actual Depron is tough to come by in the states but...
Try these sites: http://airdyn.com/zepron.htm
http://206.19.206.56/takeoff2000.htm
Don't have a source for Coroplast. Sorry.
Glues. Most of the "odorless" CA's are foam friendly, but I generally use epoxy, or a white glue like "Weldbond" or "Probond".
Foamcutters. Yikes! Where to start? Your best bet is a search through other threads, but....
You'll need an adjustable power supply capable of about 15 volts. (Old "Lionel" train transformers have been used. )
I believe a good standard power supply can also be used, and linked with a household type "dimmer switch" for adjustment.
Then you'll need to find some "ni-chrome" (sp?) wire. No source for this either. You make a "bow" out of a non-conductive material; then stretch the wire between (like a bow and arrow set-up.)
The power supply is connected to the ends of the bow wire. The current heats the nichrome wire, which melts it's way through the foam. You regulate the current to control the speed of the melt (cut).
Good Luck with your pursuits!
Dennis-
DBCherry is offline Find More Posts by DBCherry
i have had it with rc i quit all my stuff is going for sale new flyer Electric Plane Talk 157 Apr 10, 2008 07:58 AM
ok obviously i cant run motocalc...help me asjeep Power Systems 2 May 14, 2004 03:18 PM
Can anybody with Ecalc help me? How much thrust will a 5x5 prop make, at 19,000 rpm? I FO nut Electric Plane Talk 25 Jul 01, 2003 09:26 AM
Newbie with problem, help me!!! montu Beginner Training Area (Aircraft-Electric) 21 Dec 13, 2002 05:31 PM
I have had it with my Mini Piper! DavidJ Foamies (Kits) 11 Nov 30, 2002 08:10 AM
