Old May 08, 2004, 10:09 AM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Has anyone ever "baked" on a paint job?
I figured this would be best discussed in scale.
Has anyone ever baked on a paint job by putting the model in an oven? Enamel should be much tougher if baked on. A friend said he's done it before at ~200 degf. Would it do anything to the wood? I'm talking about a balsa plane that's glassed...
Thanks.
Sal C is offline Find More Posts by Sal C
Old May 08, 2004, 10:50 AM
Bomberguy is offline
Find More Posts by Bomberguy
Turrets Syndrome?
Bomberguy's Avatar
Marina Del Rey California
Joined Dec 2003
I have accelerated the cure of epoxy/glass in the oven at 150F with no ill effects, but never 200F. You could always make a sample and try it.
Bomberguy is offline Find More Posts by Bomberguy
Old May 08, 2004, 10:56 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I sometimes set mine out in the Wyoming sun( and it's warm at 4500'). Speeds up the drying and doesn't seem to hurt.
J
J Morgan is offline Find More Posts by J Morgan
Old May 08, 2004, 05:33 PM
JerryHall is offline
Find More Posts by JerryHall
Ravenna,Nbraska
Joined Sep 2003
John..
With the winds we get this side of the Divide, are you sure maybe you aren't benifitting from a supercharged airdry....LOL
JerryHall is offline Find More Posts by JerryHall
Old May 08, 2004, 09:25 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
That's true. Alot of times when I'm painting small parts, I'll take them outside and hold tham in the wind and sun. Ready for another coat of acrylic in just a few moments!
J
Old May 09, 2004, 06:53 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Sounds like a fun experiment.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old May 20, 2004, 12:21 PM
uscra112 is offline
Find More Posts by uscra112
Mid-Michigan
Joined Aug 2002
Read up on the specific paint you intend to use. Many years ago I worked building a complicated, low-production scientific instrument, and our engineer decided to use a bake enamel for toughness on the front panels. WHAT a pain! I learned that some enamels ARE formulated to be baked, and some are not!
uscra112 is offline Find More Posts by uscra112
Old May 20, 2004, 09:17 PM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Why not build a booth as in full sized auto's use. Then use lightbulbs for the heat source. Lining the booth with alum. foil, shiny side out, would allow better radiation/retention. The booth sized to hold the assemblies with ample clearance. Foam my be a good building material. It could also be made collapsable
I"ll have to give this some consideration.
Steve
St. Martin is online now Find More Posts by St. Martin
Old May 20, 2004, 10:19 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
It depends what kind of paint you use. Alkyd enamel is strengthened if baked at 200-250oF. Acrylic/latex enamel would probably be damaged.
The wood shouldn't be affected because it was already kiln dried. I wouldn't do it in an oven that will be used for food. You never really know what's in a paint.
Rick.
rpage53 is offline Find More Posts by rpage53
Old May 21, 2004, 12:27 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Of course, to high heat could cause different expansions of the wood vs. the finish. Not sure of the values of either, as to which would expand more, or the percentages of expansion. I would play it safer at a lower heat, for modeling purposes.
And the glue joints may suffer if the type is not considered. Also the american Ryan kits have foam cores. These are sure to swell, as air is part of their medium.
Steve
Old May 21, 2004, 08:06 AM
uscra112 is offline
Mid-Michigan
Joined Aug 2002
Rick as usual brings the actinic light of genuine expertise to the subject that I only see thru a glass darkly.
Another thing - the coating thickness of the enamels I was using was .003 - .005 inch. Heavy!
Has anyone ever put ailerons on a Wattage Spowith Camel spitfiremk3 Parkflyers 7 Apr 26, 2005 08:12 AM
Has anyone ever added the ailerons on a Slow Stick? FreshPez Parkflyers 47 Jan 13, 2005 08:23 PM
Has anyone ever had problems with the PH10 on 4 cells? mattijs321 Power Systems 3 Aug 23, 2004 08:05 PM
Has Anyone Ever Built One of These? Acer Electric Sailplanes 4 Dec 02, 2001 04:38 AM
Has anyone ever owned a Worlds Model Corsair? campbell Scale Kit/Scratch Built 0 Apr 23, 2001 11:33 PM
