Old May 07, 2004, 05:27 PM
buzzbee is offline
Find More Posts by buzzbee
buzzbee's Avatar
Boulder , CO
Joined Oct 2003
Brushless for Slow Stick AP - Sugestions
I am looking to go brushless on my Slow Stick that I use for AP with a Pencam SD. because of price concerns, I have been looking at the Himaxx, but I have no idea what to get.
Any thoughts would be greatly appreciated.
buzzbee is offline Find More Posts by buzzbee
Old May 07, 2004, 05:41 PM
MX is offline
MX
Find More Posts by MX
MX
Embedded Systems Engineer
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Mine works great with a Himax 2015-4100, phoenix 10 ESC, and 3s 1500 Lipos. It's
mounted in a GWS 300C-D gearbox with a CNC adapter. I think you can find all that
stuff at http://www.allerc.com. Prop is GWS 11x8.
MX
MX is offline Find More Posts by MX
Old May 07, 2004, 06:48 PM
buzzbee is offline
buzzbee's Avatar
Boulder , CO
Joined Oct 2003
MX,
I am currently using 8 and 9 cell Kan-1050 NiMH batteries. Any idea how this would work with the 2015-4100?
thinkng is offline
Find More Posts by thinkng
back to it
thinkng's Avatar
Iowa
Joined May 2003
I'm running the Himaxx 2025-4200 with a GWS "D" gearbox, 12x6 prop and 8 cell KAN's - 1050's. My initial hang up with the set-up was having to find, then install, a new GWS 350 10T pinion. I really like the performance of this motor but would like to try the Nippy or PJS and eliminate a gearbox. You won't be disappointed.
thinkng is offline Find More Posts by thinkng
Old May 07, 2004, 06:51 PM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Originally Posted by buzzbee
MX,
I haven't tried it, but with the 9-cell, probably similar, although a little
heavier.
MX
Old May 07, 2004, 11:20 PM
DrBill is offline
Find More Posts by DrBill
I need a new plane STAT!!
DrBill's Avatar
Rhode Island
Joined Sep 2003
I'm running mine currently with Himaxx 2015/4100 in the same GB as MX using 8 cell KAN1050s. SWEET! Will be trialing 9cell KAN1050s this weekend hopefully of the weather holds.
DrBill
DrBill is offline Find More Posts by DrBill
Old May 21, 2004, 01:31 AM
buzzbee is offline
buzzbee's Avatar
Boulder , CO
Joined Oct 2003
Just an update. I went withthe himaxx 2015-4100 flying with 8 cell Nimh and 9 cell Nimh Kan 1050's. Just a quick test flight today. It was pretty windy, so no high altitude flights yet, but it really is nice.
Old May 21, 2004, 06:52 AM
simonbryant is offline
Find More Posts by simonbryant
London Heathrow, Great Britain (UK)
Joined May 2004
Hi Guys what would be the performace difference between say a Himax 2025/5300 on a GWS D gearbox 12X6 prop or a Nippy 1810/100 Direct drive with 12X6 prop, based on a 2S2P 2 cell 2400mA LIth-poly.
Regards
Simon
simonbryant is offline Find More Posts by simonbryant
Old May 21, 2004, 11:27 AM
buzzbee is offline
buzzbee's Avatar
Boulder , CO
Joined Oct 2003
Simon - I have no idea - Brushless newbie, but I am sure someone will know.
I got in a flight on my 2015-4100 on 9 cell Kan 1050 11X8 prop this AM and wow. In 3 minutes I had as much altitude as I used to get in 8 minutes. This is a pretty nice setup. I think it will end up being easily removeable so I can use it in my Mountain Models smoothE as well.
Old May 27, 2004, 04:09 PM
2bent is offline
Find More Posts by 2bent
2bent's Avatar
Arlington, VA
Joined Mar 2004
What would be the difference perfromance-wise between the 2015 and the 2025 when running it on a 7 or 8 cell 1100 mah nimh? Just thinking about a brushless motor- these seem like they work pretty well.
2bent is offline Find More Posts by 2bent
Old May 28, 2004, 05:03 AM
netsurfer is offline
Find More Posts by netsurfer
Northern Ireland, UK
Joined May 2004
I have probably gone totally overboard with this, but oh well, it'll be fun! Just ordered:
HiMaxx HA2025-5300 with Phoenix 25A ESC, 2s1p 2600mAh LiPo motocalc says it will pull it vertical @ over 1800fpm on my stock "D" (6.6:1) gearing with 1280 prop at 18.6A full throttle and 9A level flight (63% throttle)
Will probably end up governing it with EPA on my radio so as not to pull the wings off No probs getting altitude now for my AP fetish
Only reason for going totally overboard is so that I dont have to upgrade for my next model.
Will post pics when the stuff arrives, and when I test.
Pete
netsurfer is offline Find More Posts by netsurfer
Old May 28, 2004, 06:01 AM
Joined May 2004
Pete
With that Battery and ESC you could of gone for the Nippy 1812/100 Outrunner,
It's a lighter motor but delivers more static thrust and less amps...
I looked into about 20 different brushless setup for the SS and the Nippy Outrunner seemed to be the best overall option, will go virtical and nearly out of site at 3/4 quarter throttle...
with an 11x4.7 prop on the 2S will produce 28.6 OZ of thrust at 15.5 amps...WOW
with a 10X4.7 prop on a 3S will give you 42 OZ of thrust at 21 amps...crazy power....
Simon
Old May 28, 2004, 10:01 AM
Joined May 2004
I dont have a lot of patience
Guess I should have looked around a bit more, but it seemed like a tossup between the Model Motors MiniAC and 4.43 gearbox or the himaxx with stock 6.6 gearbox. Main reason I went for the himaxx in the end was guys here use em, and aircraft-world were out of MiniAC's
The 2025 is still .05oz lighter than the stock 300c motor
Pete
Old May 28, 2004, 10:13 AM
Joined May 2004
Pete
You'll still have buckets of power.....just remember on full chat your gonna eat them amps....
Simon
Old May 30, 2004, 06:47 PM
Joined May 2004
Change of plans I think... Order for Motor didnt go thru. Thinking about a nippy now, how do I go about fitting it to the fuse? Any pics appreciated
Pete
landing gear for slow stick and AP (forward mount) Nethole Aerial Photography 20 May 16, 2005 11:58 PM
Question Brushless for the Slow Stick? Crazyrcer Aerial Photography 32 Oct 27, 2004 05:56 PM
Which Brushless for Slow Stick?? simonbryant Aerial Photography 28 May 25, 2004 07:41 PM
Brushless for Slow Stick RMac Beginner Training Area (Aircraft-Electric) 8 Apr 12, 2004 10:29 AM
Brushless for Slow Stick? yodasands Parkflyers 15 Apr 20, 2003 10:29 PM
