Old May 06, 2004, 02:27 PM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
Question
Phoenix-80 max power question
I am setting up a Surprise 11 with an Aveox F12 for F5F. I will be using a gp3300 X 10-battery pack and probably a 15 X 15 prop. How should the timing and frequency be set to get maximum power from this set up? Are there any other settings I can tweak to get more power? Because of the minimal motor run in F5F I usually only use < 1300 ma from the packs so I donít care if I draw more current. I just want maximum possible power.
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old May 07, 2004, 02:41 PM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
For max power, use the highest PWM frequency, and the highest timing advance settings.
Shawn
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old May 10, 2004, 12:37 PM
Joined Jun 2001
Thanks Shawn. I will report on how it goes after I get a chance to test fly. This is the first CC controller in use with our Portland area F5B group. Everyone wants to see how it goes, they also want a controller to handle up to 180 amps. I, of course, wonít be pulling that many with my set up, Surprise 11, Aveox F12, 10 GP3300, 15 X 15 RFM thin prop.
Bernie
Old May 10, 2004, 03:09 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
PWM frequency should not have any effect in the F5B application as it is at full throttle or off. Timing is a different matter and in most cases you should use the setting that gives the best efficiency, which for you motor would be the lowest advance. While you can get a bit more power with more advance --it has it's cost in reduced efficiency and more heat in the motor and controller. I find it better to change or adjust the prop pitch than using too much advance.
Steve
sneu is offline Find More Posts by sneu
Question Phoenix 80 max volts and amps. Synth Castle Creations 0 Mar 22, 2007 03:30 AM
Phoenix 80 only putting out half power soholingo Castle Creations 6 Dec 25, 2004 12:09 PM
CC Phoenix 80 controller question MikeC Castle Creations 7 Feb 27, 2004 01:08 PM
External BEC with Phoenix 80 Question Bill Sanford Castle Creations 3 Feb 20, 2004 09:53 AM
Phoenix line of ESC power up question Mike Parsons Castle Creations 4 Jul 04, 2003 06:09 PM
