One hour CD ROM construction part 6
One hour CD ROM construction pt 6
continued on from here: http://www.rcgroups.com/forums/showt...83#post2133783 |
Bozeman, Montana
Joined Dec 2003
Double ended motor
Amos,
For the double ender, I would try to align both the stators on the bearing tube and the bells (as long as they are identical mag/pole configurations). If you have remag'ed the bells, aligning shouldn't be a big task. (Pinpointing the N/S poles on the stock ring mags can be fun, but it should be possible to get close enough with little effort.) If everything is reasonably precise you should be able to parallel the windings on a single controller with no problem. Your actual output will depend on the precision of the alignment, but reasonable care should get you in the high 90 percentile of the sum of the outputs of the individual motors. If separate controllers are used, you will not be able to attain the same max because of 'firing' variations between the two controllers (there might also be some obscure non-linear load balance issues between the two controllers). John |
My friend tried once and I heard it was very tricky. He used Jeti Advanced 8A? controller. Needed to try a few times to start both spin. Once they are spinning, it is ok unless you stop them. (cannot restart!) This makes flight very tricky. If he stops and starts the motors in the air, it is likely only one motor spins, creates unballance and resulted in spiral! Need to land without power. I do not think you damage the controller unless you force it run continuously with one motor stalled. Satoru |
Hope this helps. Satoru |
| Thread Tools | |
| One hour CD ROM motor construction PART2 | Takao Shimizu | Power Systems | 754 | Sep 08, 2010 12:12 PM |
| One hour CD ROM construction part 7 | rysium | Power Systems | 806 | Dec 18, 2006 02:58 AM |
| One hour CD ROM motor construction PART 4!! | t-turley | Power Systems | 555 | Jun 07, 2004 07:33 PM |
| One Hour CD ROM Construction Part 5 | arx_n_sparx | Power Systems | 537 | May 07, 2004 09:56 AM |
| One hour CD ROM motor construction PART3 | rysium | Power Systems | 511 | Mar 22, 2004 01:03 PM |
