Old Sep 07, 2001, 02:33 PM
mt_100 is offline
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
I need a new "Lazy Plane" Suggestions?
I fly from a large field and want to get something other than my usual hand launched S400 stuff.
I am looking for a high wing lazy flyer that I can over power. The reason I want to over power it is so it will cruise at very low power setting for nice long flights.
I was thinking of the Hobby Hanger Scout, or the GP PT-E but I don't want to buy new motors if I have to. Currently I have a Turbo 450 that I thought I could gear to get good performance out of using my 8 cell 800 AR and 8-1400AE packs.
Any thoughts on a good ROG flyer that will do touch and goes all day long and fly off grass on that combo? If not what do you recommend.
One benefit would be a cheap kit or plans, free plans are great too if there are any.
mt_100 is offline Find More Posts by mt_100
Old Sep 07, 2001, 07:42 PM
mt_100 is offline
I have no friends
Joined Dec 1996
Move up.
Old Sep 07, 2001, 07:47 PM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
Have you thought of a Miss 2 or a Hummel? They are very nice planes that fit your description and power requirements. Both sold by Multiplex I believe.
They are both essentially the same plane with a little different wing. The down side is that they are around $100. Too bad I didn't see this post as I just sold one off cheap. The quality of these kits is VERY good. ---Rob
slowflyer is offline Find More Posts by slowflyer
Old Sep 07, 2001, 08:31 PM
Scott C is offline
Find More Posts by Scott C
son of a pilot
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
SR's Cutie, no doubt about it. I have mine overpowered with a black 480 clone with the standard gearbox and prop. Slow or fast, my Cutie is a delight to fly. Short-field takeoffs are great with a short 90 degree pitch angle climb for about 10 feet.
Scott
[This message has been edited by Scott C (edited 09-09-2001).]
Scott C is offline Find More Posts by Scott C
Old Sep 07, 2001, 10:46 PM
mt_100 is offline
I have no friends
Joined Dec 1996
Those are great, but still 400 size. I'd like to go a little bigger, 600 size range.
Also, those are way to expensive.
Old Sep 08, 2001, 03:27 PM
mt_100 is offline
I have no friends
Joined Dec 1996
What about the Bubbles design I see plans for?
I though a DD T450 or geared 450 would be great on it. That way I can use the 800AR and 1400AE packs I have and get a decent sized plane.
What if I made the fuse side from 3/32 menium balsa instead of open framework? It would really cut down the build time.
Old Sep 09, 2001, 07:07 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
A PS Flyer might be what your are looking for or maybe a Piece 'O Cake.
Ken Myers is offline Find More Posts by Ken Myers
Old Sep 09, 2001, 09:34 AM
dwatkins is offline
Find More Posts by dwatkins
Angola, IN USA
Joined Mar 2000
Mirage 550 with Geared Endoplasma/7 cells and 10x7 E prop. Will fly all day on 1/4 throttle, ROG and T&G. Total setup cost:$260 including battery pack (2000nimh). www.goldbergmodels.com Requires minimum 35 Amp ESC with this setup.
I have a nice green/white one with r/e/t can also be modified for ailerons. Will do sustained inverted flight with this motor and ailerons (or just with rudder if you're VERY careful) Also thermals!
DPW
dwatkins is offline Find More Posts by dwatkins
Old Sep 09, 2001, 11:05 AM
mt_100 is offline
I have no friends
Joined Dec 1996
The Mirage 550 and Hobby Hanger Scout are two of the planes I am looking at. I also downloaded the Bubbles plans and it seems like a great choice.
Anyone notice that the Goldberg models went to $87.99 for the Mirage!
Old Sep 11, 2001, 08:31 AM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Depends upon how "Lazy" you want to get. I have discovered what I consider an extreme lazy flyer in my 1941 Cabin Playboy, an old timer I built from a kit from New Creations (the Aveox kit). For power I used a packaged system from Dymond consisting of a 550 with in-line gear box, yoke, spinner, and proper prop all for only $70. The bat pack is 8-1000's.
It will ROG in 10 feet, climb out at 35-45 degrees and once up there, dial in a few clicks of rudder, set the xmtr down and go get a coffee ( I have actually done this ). A real frequency pin hog.
You can repeat the climb outs as many times as your buddies will allow you to hog the frequency.
The Playboy has become one of my favorites.
RonJ is offline Find More Posts by RonJ
Need new razor plane robert harik The Builders Workshop 26 May 15, 2014 02:41 AM
I need a new hot plane newflyer Electric Plane Talk 20 Jan 16, 2005 09:01 PM
Need a new Ap Plane for 5 - 10 mph winds drvcrash Aerial Photography 11 Jul 21, 2004 03:37 PM
Need a new a F5F Plane what to get? GoodTill High Performance 3 May 10, 2004 03:17 AM
A new scale plane? Suggestions on what to design. Van Scale Kit/Scratch Built 69 May 21, 2002 05:19 AM
