Inexpensive charger recommendation *please help*
I have three 2s 450mah lipo that I need a charger for.
I don't plan on having anymore electric planes, so I need something cheap but will do the job without ruining the batteries. What charger will work that is relatively cheap that can charge all 3 batteries at once? All help is appreciated!! |
I believe you believe you will not have any more electric planes. But you will. So; this would do it
Or this This would take you a little farther down the road And there are better, but more expensive chargers than this. You may want to think about it more because you will have more electric planes. Disclaimer: I don’t endorse the first two and you will have to make a parallel charging cable to accommodate the safe charging of the batteries. |
Reason: Added disclaimer
Would I be able to plug in a parallel board and charge three 2s batteries at the same time with this one? |
Therefore your only problem would be to find a parallel board that can connect to a 4S port on the charger. However the only parallel boards I am familiar with are for 6S. Here there are some balance cables that work on 2S and 3S: https://www.hobbyking.com/hobbyking/s...rallel+balance You would also have find a parallel lead for the main charge cable. Glen |
That parallel board will work. Just remember when parallel charging set the charge rate to the sum of the batteries’ currents. The voltage remains whatever it is. For instance with the 2 cell set the charger to 2S or 7.4 V. for 3S set for 11.1V.
Do not mix 2S and 3S during the same charge set up. |
With that board you could use a charger that makes connection to the power leads as well as the balance leads. The Sky RC E3 will only provide charging power and balance through the balance leads
The Sky RC E4 and the Dynam Supermate—and better chargers—will charge through the power leads and balance through the balance leads. |
Just want something to charge these 3 only batteries. When it says 1A 2A and 3A, which setting do I put it on for these 2s? |
In your first post you wrote you have three 450 mAh batteries. Since that is close to .5A you could set the charger to 1A for two at a time and either 1A or 2A for all three at one time.
With three in parallel it would be a total of about 1.5 Amps (that’s .5A X 3) so if you charged three at one time with the charger set to 2A that’s about 33% above 1C. Most good batteries should be able to take a 2C charge. If you want to be conservative charge them at the 1A setting and you will not be charging them above 1C then. |
Thread Tools | |
Similar Threads | |||||
Pleas help recommend charger | TheTick | Batteries and Chargers | 26 | Jun 04, 2017 02:31 PM | |
Discussion | Desperate plea for help, 2 quadcopters fully built, neither will fly | Six_Sigma | Beginner Multirotor Drones | 37 | Apr 03, 2017 12:44 AM |
Discussion | DX7S programming help pleas | ledpole | Fuel Plane Talk | 2 | Feb 15, 2017 08:07 PM |
Help With Charging Li-Po's With Triton Charger Pleas? | Synthetic | Batteries and Chargers | 13 | Dec 17, 2004 09:08 PM | |
RealFlight g2 Multiplayer pleas help | Pablito | Parkflyers | 0 | Apr 27, 2002 08:44 PM |
