Old May 03, 2004, 08:07 PM
davekra is offline
Find More Posts by davekra
Milwaukee G Mitchell, Wisconsin, United States
Joined Mar 2002
How much throw on the P51's ailerons?
If you were about to glue your wing to the fuse on your Patton 48” P51 how much throw would you give to the ailerons?
I’m using two servos for the ailerons so I can experiment with the “land” setting on my Eclipse 7 and to have better control over trimming them out. I always seem to have too much throw so I thought I would pose the question before closing it up.
Anyone?
davidk
davekra is offline Find More Posts by davekra
Old May 03, 2004, 08:44 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
I would give my ailerons as much throw (not through heheh) as possible. Since you have an Eclipse, you can always cut down the throw with dual rates, EPA and/or exponential, but once you glue that wing on you can't get any more.
Get your pushrod attachment point on the torque rod as close as possible to the wing surface so that you have as much mechanical throw as possible. Then use the longest arms you can fit inside the fuse on your servos and connect the pushrod at the furthest out hole possible.
IMHO there is no such thing as too much aileron throw!!
Steve
surfimp is offline Find More Posts by surfimp
Old May 03, 2004, 09:40 PM
davekra is offline
Joined Mar 2002
As I have it now there's about 1" of travel up and down. Switching on the landing mode moves them both down about 5/8". That plus the aileron movement moves them down as far as they can go. Does anyone else use flaps on one of these PSS ships? Would it even be controllable with the flaps deployed? The first pic is of the linkage. Because of the way the servos are installed I figured I needed ball links.
davidk
(a proud product of publik schooling)
Old May 03, 2004, 09:53 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
Joined Apr 2003
I've used 2 servo set ups on some PSS planes but I honestly don't think that they buy you much, if any advantage. I really never used them for landing, they take a good hit being unprotected by a fuselage if they are left down on impact. They don't buy you much lift on the shorter lower aspect wings and they are not of any use in reflex either. I now only use one standard servo, even on the big LEG 60"ers or the Super Tucano that I'm working on. But hey, like Surfimp sez: go for it, you've got it in place...I like the scrunched in, angled servos. Very creative!
Droydxxx
droydx is offline Find More Posts by droydx
Old May 03, 2004, 10:02 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Anyone?
davidk
How good are ya? If you have a computer radio set the mechanical linkages up so that they move as far as possible. Then in your programming set your high rate so that you have about 45 degrees of throw AND about 75% exponential. Set the low rate at about half of that and set the expo at about 50%. First flights use the low rates and if you want more switch to high, then adjust to taste. Always set the mechanical linkages for MAX throw.
Seperate servos are nearly useless on 48" warbirds. I would normally say completely useless but there's always somebody, somewhere, that one time when the earth rotated backwards, that one day found two servos helpfull to make a landing on some isolated spot of grass.
TFLG
TFLG is offline Find More Posts by TFLG
Old May 03, 2004, 10:52 PM
davekra is offline
Joined Mar 2002
TFLG
Sure I could do one servo. And, yes, the flap thing is just an experiment. But with the linkages sealed in the fuse having two servos allows adjustments that would otherwise require adjusting the linkages. I was planning to bolt the wing on but I did'nt feel it was a solid enough connection so back to glue.
I've got to get this thing ready for paint by the end of the week. I'm going to South Dakota on the 18th for 5 days of slopin, WOOHOO.
davidk
Old May 03, 2004, 11:18 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Be aware if you flip both ailerons down that far your plane is very likely to pitch up 90 degrees in a heartbeat. If you plan on messing with moving the ailerons you are FAR better off going the OTHER direction. Have both of them move up (spoileron). This is a much more controlable method of landing a plane. When you deflect them down you loose too much aileron response.
Spoileron = good
Flaperon = bad
TFLG
Old May 04, 2004, 12:56 AM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
If it were me, I would try to get those nylon connectors down further. I would get them as close to the surface of the wing as possible, without them binding or hitting the wing surface itself at full deflection. You can always reduce it in your radio if need be, but there's nothing--NOTHING--quite as awesome with a PSSer as a good old 1080* per second roll rate. But I like fast rolls, so take that statement with a grain of salt!
Steve
Old May 12, 2004, 07:29 PM
davekra is offline
Joined Mar 2002
Are you guy’s nuts!
I did move the connectors down some. I’ll have to measure just how much throw I have now but it’s more than I had when I posted the pic’s. The wind was rippin today from the south. I was on top of the ski hill (garbage dump) and gave the P51 a heave…5 seconds later it was down. The flight was toss, going down pull up, almost stall give down heading right give left, inverted pull up and land (bounce) on the side of the hill. (note to self, if you put ballast under a hatch that can come off tape it in) Dial in a lot of expo and give it another toss. This time a sloppy run out and circle to the left and land, this time a planned landing. Looked like I was flying drunk. I’ve got to setup some dual rates to reduce the throws till I learn the handling. Should be a great time in South Dakota starting Wednesday.
Old May 12, 2004, 10:40 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
On my 48" foamies I have as much aileron throw as I can get!!! Not too much elevator throw--- but my ailerons can move past 45 degrees on most of my warbirds! Then I use dual rates and exponential to take a little of the edge off sometimes-- but we all love to roll as fast as possible-- the B-17 in my other thread will do about 6 rolls per second!! But then--- we're PSS Fanatics!!!!!!!!
timmig is offline Find More Posts by timmig
Formosa Finished - How much throw on controls surfaces? mrebman Parkflyers 2 Nov 15, 2003 02:30 AM
How much power do Lipo's lose in cold temps??? duganderson Batteries and Chargers 1 Sep 28, 2003 11:09 PM
How much throw on E-starter Ailerons? Freddy418 Parkflyers 2 Jun 12, 2003 11:13 PM
How much is spent on your hobby? Whizwaz Electric Plane Talk 86 Feb 05, 2003 04:35 PM
How much flaps on Mini flash? juantrinidad Parkflyers 0 Nov 25, 2002 02:20 AM
