Old May 03, 2004, 04:01 PM
Forest is offline
Find More Posts by Forest
Forest's Avatar
London
Joined Dec 2003
Question
JePe Pyranha Mega 16/20/2
I am about to buy a JePe Pyranha and it has been suggested to me that I use a Mega 16/20/2 motor (which is normally used for boats), Wemotec 480 mini fan and 4 lipo cells.
Is anyone else using this setup? I am also looking for an appropriate esc around 40amps and have considered the CC Phoenix 45.
The other suggestion was to use the new Kontronic Konion 1100mah cells.
Any and all suggestions would be appreciated and considered.
Forest
Forest is offline Find More Posts by Forest
Old May 03, 2004, 05:01 PM
JimF is online now
Find More Posts by JimF
Ellington, Connecticut, United States
Joined Apr 2001
I have one, unflown (too many other priorities in life right now) and I think most folks are using the Mega 16/15/3 or /2. JePe sells the combo with the 3 turn mega. Some others are using the Kontronic Fun 400 motors. Do a search on Pyranha or MiniViper and you'll find a few threads with all sorts of info.
I don't know about the 16/20/x motors
Jim
Jim
JimF is online now Find More Posts by JimF
Old May 03, 2004, 06:02 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Mega 16/25/3 (kv=1700) needs a lot of cells (20 cells or 6s) in the MF480 to get going. It's a poor choice for the MiniFan, the Mega 16/15/3 is the way to go Mega-wise (as btw recommended by JePe).
http://www.rcgroups.com/forums/showt...&page=12&pp=15
Herb is offline Find More Posts by Herb
Old May 04, 2004, 03:45 AM
Mikael is online now
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Mega 16/20/2 kv=3100 weight 106 grams
Mikael
Mikael is online now Find More Posts by Mikael
Old May 04, 2004, 03:56 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
For 4S packs the 16/20/2 looks good though no one have experience with it yet. The Konion's look real good with their 12C continous rating.
I have tested a Konion 3S3P pack with the Fun400-42 in the Minifan and got 400W/38A.
Haldor is offline Find More Posts by Haldor
Old May 04, 2004, 04:12 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
16/20/2 was created at request by www.HAB.se for use in Robbe Eolo/Spirit.
Mega runs well on Jeti and TMM escs, where Jeti is faster throtteling and tmm is more efficiant.
henke is offline Find More Posts by henke
Old May 04, 2004, 11:47 AM
devmonkey is offline
Find More Posts by devmonkey
United Kingdom, England, Surrey
Joined Aug 2002
The optimum mega lipoly minifan setup I have found is a 4S2P irate 1800 pack (~300g) with the 16/15/3. 450watts fading to 420watts, pack comes out warm not hot after 9mins flight - mostly WOT.
devmonkey is offline Find More Posts by devmonkey
Old May 04, 2004, 02:09 PM
Forest is offline
Forest's Avatar
London
Joined Dec 2003
Thanks for all the replies.
I am swaying toward the 16/15/3 on 4s2p Irates as Devmonkey suggests. Do you know what amperage the Irate 1800 4s2p are capable of continuous?
Herb, don't know where you got 16/25/3 from?
I asked about the 16/20/2 which apparently is a brand new motor and although it is heavier (I am told that it is on the 480 size motor instead of the 16/15/3 which is around the 400 size) is capable of maintaining its power on 4s while the 16/15/3 drops off a little.
Just trying to weight things up.
Keep it coming...I love different opinions.
Forest
Old May 19, 2004, 07:44 AM
geoff.sim is offline
Find More Posts by geoff.sim
geoff.sim's Avatar
Northamptonshire, UK
Joined Oct 2000
I bought a pyranha at the UK Bickley meeting. Jepe was there and I found it hard to refuse a kit!
The power plant will be:
Hacker B40-12s.
Hacker 40-3p s/c.
Four 2S1P packs of Polyquest 2200 cells used in 4S2P format (352g).
This pack is 10C rated continous (44A) but 8C is best for optimal life (35A).
Geoff.
geoff.sim is offline Find More Posts by geoff.sim
Old May 19, 2004, 10:30 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Forest
Well then, I'm running the Kontronik 400-36 with a smile controller 40-8-12
on 11 zapped 1950 FAUP's.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jun 03, 2004, 02:20 PM
geoff.sim's Avatar
Joined Oct 2000
Heres mine almost ready to paint.
I decided to glass the wing/tail feathers and all has worked out fine.
Estimates of weight suggest that mine may be slightly over the 1050g suggested limit.
I found the most time consuming part was working on the inlets...
Geoff.
Old Jun 03, 2004, 04:29 PM
Joined Dec 2000
The inlets do take time. Yours look great.
Old Jun 04, 2004, 01:44 AM
demetrius is online now
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
i'm curious to did you glass or dope and did you use silk?
Geoff.
demetrius is online now Find More Posts by demetrius
Old Jun 04, 2004, 02:50 AM
geoff.sim's Avatar
Joined Oct 2000
I used 1/2oz glass cloth and finishing resin. I used a credit card to squeegee the surplus resin off and used a cellulose filler/primer to fill the weave.
Old Jun 04, 2004, 12:52 PM
geoff.sim's Avatar
Joined Oct 2000
Here she is with a basecoat on. I have a lot of this colour, so I thought why not. Now I need to work on visibility. Any suggestions as to a colour scheme with this as the base?
Geoff.
Help! Rbc Mig 29 Mega 16/20/2???? kovar Electric Ducted Fan Jet Talk 7 Feb 25, 2007 04:12 AM
Question Mega 16/20/2 imodel Electric Ducted Fan Jet Talk 9 Dec 31, 2006 06:47 AM
Sold Mega 16/20/2 EDF HotRod DIALED/CHUCK Aircraft - Electric - Power Systems (FS/W) 4 Dec 19, 2006 12:55 PM
Mega 16/20/2 in a Minifan like2fly! Power Systems 0 Oct 07, 2005 09:00 AM
New Mega 16/20/2 TMorita Electric Heli Talk 0 Apr 23, 2005 04:18 PM
