Old May 03, 2004, 12:12 PM
dcairns is offline
Find More Posts by dcairns
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
CG Calculators on a swept wing...
This might be good for a bit of debate Most CG calculator programs work off the root and tip chords as the amount of sweep. Do you think I should use the root chord that is buried in the fuselage or the root chord where it emerges from the fuselage?
On more normal planes with only slight sweeps and tapers this is not much of an issue, but my B-52 has a highly swept wing with good degree of taper, not to mention a rather fat fuselage for a sloper. Depending on what "root" chord I use, the calculated CG will vary quite a bit. My inclination is to disregard the "buried" part of the wing and use the dimensions of wing that is actually flying. On the other hand, the fuselage does provide some "flying surface"....
dcairns is offline Find More Posts by dcairns
Old May 03, 2004, 12:36 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
You DO factor in the wing that is inside the fuse.
TFLG
TFLG is offline Find More Posts by TFLG
Old May 03, 2004, 03:16 PM
dcairns is offline
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
Ok, good answer. Care to explain why that is?
I am assuming these CG calculators are simply using a geometric solution. So if more of the wing is inside the fuselage, and not a "wing" there is more opportunity for error.
Old May 03, 2004, 03:17 PM
spitfirem9 is offline
Find More Posts by spitfirem9
Blue skies forever!!
spitfirem9's Avatar
Orange County, CA
Joined Nov 2003
The CG is always factored at the root chord. Use TFLG's CG calculator on his site:
www.slopescale.com
I used it on my highly swept-wing P-51 ""Miss Ashely II" and the CG was at the exact location on it's maiden flight.
Jeff Vosburg
spitfirem9 is offline Find More Posts by spitfirem9
Old May 03, 2004, 03:52 PM
trippme is offline
Find More Posts by trippme
Laguna Beach, CA
Joined Mar 2003
Is that site up? Just tried it and got "coming soon" page.
trippme is offline Find More Posts by trippme
Old May 03, 2004, 03:59 PM
dcairns is offline
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
I am willing to believe you guys, just being annoyingly curious .
I still don't see why a part of the wing that is not contributing to flying, should be counted in figuring the CG
Wish I had my wing dimensions handy so I could run the numbers both ways and see what the difference in CG comes out to be. Perhaps it is not significant.
Old May 03, 2004, 04:00 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
The address is wrong try this.
http://ourworld.compuserve.com/homepages/slope_scale/
or if you want to go right to the CG calculator
http://ourworld.compuserve.com/homep...le/page17.html
TFLG
Old May 03, 2004, 04:26 PM
kingdavey is offline
Find More Posts by kingdavey
kingdavey's Avatar
Joined Apr 2003
Can that calculator also be used for non-standard planforms, like an elliptical wing?
What would you do different?
kingdavey is offline Find More Posts by kingdavey
Old May 03, 2004, 04:40 PM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
I think that's your answer. You may be right, but the difference is so small that it's not noticable.
Russ.
slopeiron is offline Find More Posts by slopeiron
Old May 03, 2004, 04:49 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
NO IT IS NOT INSIGNIFICANT, especially on a swept wing! The difference on my Carvelle worked out to almost 5/8th of an inch if I figure the CG using all the wing versus just the panels outside the fuse.
I balanced it using the whole wing and it was spot on. Had I balance it 5/8" further back I'm quite sure the first flight would have been much less enjoyable.
TFLG
Old May 03, 2004, 04:55 PM
dcairns is offline
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
Found my drawing
so plugging these numbers gives me :
23.5 - 9.5 - 50.1 - 66.5 @ 30% = a CG of 26.75
Kind of funny, the CG is behind the trailing edge of the root due to the sweep
Doing some guesstimates for not including the fuselage area, I get:
22.5 - 9.5 - 45.0 - 61.0 @ 30% = a CG of 24.52
That works out to about a 2 1/4 inch difference. That is about 10% of the root chord, so it is significant. When I get home I will come up with some better numbers and see if the significance remains.
Old May 03, 2004, 09:08 PM
trippme is offline
Laguna Beach, CA
Joined Mar 2003
What if I have a multi-panneled wing? So not just a single sweep but a double or tripple taper wing.
Any suggestions for a caculator for that?
Old May 04, 2004, 09:18 AM
dcairns is offline
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
If you did a CG calc on each panel and then averaged the CG points, weighting them based on the area of each panel, I would think that would work.
Old May 04, 2004, 10:14 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Here's a spreadsheet of a double taper wing. I think I have a triple taper one too somewhere but I can't find it.
TFLG
Old May 04, 2004, 10:58 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Multi-paneled wings take a bit of mathematical finesse. Here's the best I've found.
http://perso.wanadoo.fr/scherrer/mat...glish/mce.html
For elliptical wings, use your best judgement and make up several panels in trapezoid format, eyeballing the overage and underage to be reasonable for each segment.
Sparky Paul is offline Find More Posts by Sparky Paul
CG location on a swept wing spacemanspiff Electric Ducted Fan Jet Talk 3 Feb 18, 2005 07:38 AM
Balance Point on swept wing??? Tumbler Fuel Jet Talk 4 Apr 17, 2004 07:49 AM
CG point on a flying wing rcnutt Electric Plane Talk 4 Feb 07, 2003 09:59 AM
Getting CG forward on a swept wing design rakm Modeling Science 7 Dec 23, 2002 11:03 AM
Double Delta on swept wing do anything? hardlock Power Systems 8 Jan 03, 2002 02:53 AM
