Old Jan 03, 2002, 06:21 PM
Orion1 is offline
Find More Posts by Orion1
Orion1's Avatar
Shalersville, Oh
Joined Jun 2001
Building my first battery pack.
This may sound stupid but I'm building my first battery pack (8 AA cells) and I was wondering if I should put a fuse inside the pack or run with out one. If you do use a fuse would one of those spade type automotive fuse work?
I'm using a Jeti speed controler with a battery eliminator circuit so I wouldn't have to use an extra battery pack for the reciever.
I have a Graupner Speed 400 with a 4:1 gearbox and as I said a Jeti speed controller with 8 1600 mah AA batteries.
I was thinking if you blow a fuse you lost control of your plane because no more power to the recceiver but without the fuse you could set your plane on fire.
What do you people do.
Orion1 is offline Find More Posts by Orion1
Old Jan 03, 2002, 07:23 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
I haven't built any packs myself.. I tried one once and I think I got the cells too hot w/ the iron.. since then, I've gladly paid for someone who knows what they're doing to make em for me... I know I should at least have a fuse in my Bandit.. but I don't.. no fuses on any of my ships.... bad, very bad...
tic is offline Find More Posts by tic
Old Jan 03, 2002, 07:33 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Orion1:
Welcome to Ezone first off!
You're on the right track thinking that a fuse in the circuit to the ESC will kill everything. Correct. Literally. If you REALLY feel you need a fuse, put it between the ESC and the motor so that if the motor shorts out, the fuse will go and protect the ERSC. From all that I've gathered around here however, most don't bother with a fuse. I don't.
mw
Mark Wood is offline Find More Posts by Mark Wood
Building my first plane... Wish me luck ArcherAce Parkflyers 6 Aug 02, 2008 08:39 AM
Discussion Building my first battery pack Red_N_White Batteries and Chargers 4 Jul 19, 2007 08:35 AM
My first battery pack, ick. sizam Batteries and Chargers 28 Dec 05, 2002 08:52 PM
Need help building my first foam cut glider Steven9026 Electric Sailplanes 8 Nov 21, 2001 08:17 PM
Building my first battery packs... Gospadin Sport Planes 4 Nov 15, 2001 09:17 AM
