Old Sep 07, 2001, 04:28 PM
member73 is offline
Find More Posts by member73
member73's Avatar
Wakefield, MA
Joined Feb 2001
X-250 Set Up
I checked all the threads and have Larry's settings printed out, but what I want to know is how about for initial testing? I saw some talk of the battery being much further forward than expected (1/4" from front of tray). Where is a good point to balance for a stable first flight? And control settings for that matter.
I took my baby (http://www.ezonemag.com/disc/Forum1/HTML/008703.html) out last night for the first time and had a hair raising ride. Well I only broke a couple of props and messed up the motor mount, but I'd rather not do that again. I did make one big mistake, I haven't flown anything for about three weeks now and didn't warm up before my maiden voyage. Next time I'll be sure to take my Zagi along!
member73 is offline Find More Posts by member73
Old Sep 07, 2001, 05:46 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
CG as per instructions is fine. He talks about the range, and it's pretty much spot on. Check your wing for warps, however - was to see if you lay it inverted on a table top, and walk away from it - the bottom edge should dissapear all along the wing at the same time. I like twitchy control throws, but if you don't, set them per instructions but with low rates also for takeoff and landings..
..a
Old Sep 07, 2001, 09:45 PM
member73 is offline
member73's Avatar
Wakefield, MA
Joined Feb 2001
Tonight I took my Zagi out first. Got a couple of packs through it before trying the X250. I also had my girlfriend with me, maybe she's good luck? All I can say is wow, what a difference. The plane flies great. The only problem was I was flying from a baseball diamond surrounded by trees that was a little tight for my comfort. I can't believe how much faster the X250 is than the Zagi. I had a hard time staying in front of it for the first few minutes. I did a few landings, kept doing a three point landing at best, which isn't good for the nose gear on grass. The last landing was very sweet, greased her in. I can't wait to try it out on a bigger field to see what it can really do! It is now set up with ailerons at neutral, I might set them down a little to slow things down until I get used to it.
btw, I moved the cg forward to about 1/2"-3/4" in front of the balsa sheet joint. That seemed to work much better for me (at least for now).
Old Sep 08, 2001, 03:57 PM
Larry @ SR is offline
Find More Posts by Larry @ SR
Larry @ SR's Avatar
Bellport, NY, USA
Joined Apr 2000
Hi 73...
Don't be affraid to slow the X250 down. The stall speed is about 12mph so throttle back to just above half throttle and relax.
Larry
Larry @ SR is offline Find More Posts by Larry @ SR
Old Sep 08, 2001, 11:16 PM
tomr is offline
Find More Posts by tomr
Coram,NY,USA
Joined Oct 2000
I just finished "rebuilding" my X250
tonight hope to fly tomorrow with some
better results than I've had with the
last few disasterous outings
tomr is offline Find More Posts by tomr
For Sale Excellant X-400 set up RTF. Tophinater Aircraft - Electric - Helis (FS/W) 12 Feb 03, 2006 04:06 PM
Cool Post pics of your X-400 set up. Tophinater Mini Helis 11 Jan 11, 2006 09:34 AM
Servos/X-Tail Set-Up for Electric Graphite 2 Diesel 10 Electric Sailplanes 2 Oct 11, 2005 10:08 AM
how do you set up a ms44 with a jr 8103 pulling my hair out i'll be bald before x-mas falcon41176 Micro Helis 0 Dec 21, 2004 08:58 PM
FS: X-250 Drive set minus batts. Al P Aircraft - Electric - Airplanes (FS/W) 4 Jan 02, 2003 06:36 PM
