Old Jan 03, 2002, 03:19 AM
pade is offline
Find More Posts by pade
Stockholm, SWEDEN
Joined Jan 2001
Avro Mk IV Triplane Motor suggestion
Hi!
I have just bought a R/N models Avro Mk IV triplane kit that I intend to convert to RC. The kit is a FF-kit originally for a Cox .020 or a "Hytork 48" electric. Prop size has to be around max 5" for not hooking into the rigging.
Has anyone made this conversion and can give me some hints or has anyone a motor suggestion for me?
Thanks in advance and best regards,
Patrik Delin
pade is offline Find More Posts by pade
Old Jan 03, 2002, 09:34 AM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
Can you let us know what the wingspan is and area?
Martin Irvine is offline Find More Posts by Martin Irvine
Old Jan 03, 2002, 04:36 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Patrik
If you're certain that it can only swing a 5" prop then four choices come to mind- - HY-50F - good up to maybe 5 ounces or so, (lightest option)-
HY-50B swinging a Tern 6" prop (if it'll fit- good up to 6.5 ounces
Speed 280 direct drive- maybe your best bet- I've flown several planes that originally called for 020s on this motor swinging a 5" prop, but it's not an ideal setup- max around 8 ounces
Astro 010 brushless direct drive- a bit heavier, but more power than the 280.- Max- maybe 14 oz but I'll bet your airframe gets too heavy. Really, you want to swing closer to a 7" prop- even a 6" prop would help- that will improve your flight performance dramatically.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Discussion AVRO Mk IV Triplane Project Chevelle Scale Kit/Scratch Built 56 Dec 10, 2010 05:08 PM
Nano Gnat motor suggestion Jim Drissell Parkflyers 0 Jul 21, 2002 10:59 AM
WTB Ultra Mk IV Hudley Aircraft - Electric - Airplanes (FS/W) 0 Apr 15, 2002 08:03 PM
Corona Motor Suggestion serious_sam Electric Heli Talk 0 Mar 03, 2002 02:11 PM
Bristol Bolingbroke Mk IV (based on Balsacraft Blenheim) Fen Tiger Scale Kit/Scratch Built 13 Feb 28, 2002 04:37 PM
