Old Apr 30, 2004, 08:19 PM
TeamSME is offline
Find More Posts by TeamSME
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
Okay, okay, I'm getting a shocky
I'm getting a shockflyer soon and I know this is the 10000th thread about setups, but I would like to know a fool proof brushless setup for this plane. I need something that will hover, rocket out and pull the planearound for at least 10 minutes without fading. Could you list your batteries servos/rx and esc.
I'm so tired of bad setups.
Sean
TeamSME is offline Find More Posts by TeamSME
Old Apr 30, 2004, 08:48 PM
waykewl is offline
Find More Posts by waykewl
United States, TX, Bedford
Joined Apr 2004
Extrema 330s, Nippy Black 0808, GWS 8x4.3 prop, Phoenix10, E-Tec 3x700mah Cell, 3xGWS Pico servos, and Pico RX. This set up will give you 200g all up weight, and will meet all of your requirements. You can hover at mid stick all the time.
waykewl is offline Find More Posts by waykewl
Old Apr 30, 2004, 09:23 PM
rroback is offline
Find More Posts by rroback
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
my recommendation for easy of buying and reliability is just to use what hobby lobby recommends. simple as that. personally I've run the motor they recommend with a c.c. pheonix 10 and a razor 300 on the stock gearbox ( well optional stock one). both are great. razor is very very very ( too) powerful. axi is so nice and silent.
Rhett
rroback is offline Find More Posts by rroback
Old Apr 30, 2004, 11:12 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
I have the 540 edge, but understand they all pretty much fly similar. 2208/34 AXi, APC 10x4.7, GWS 4ch receiver, 3ea HS50, Phoenix 10 ESC and 2S1P Tanic 850 for the type of flight you want. The 340 kokam works, but does not give the same vertical performance you want. A 3 cell lipolly would give even more perfromance, but is probably overkill really. I would be afraid to climb much faster than the 2S tanics climb.
Good luck and let us know how it goes!
Steve (sitting and hoping the rain will stop so I can fly mine tomorrow)
Steve McBride is offline Find More Posts by Steve McBride
Old Apr 30, 2004, 11:37 PM
nofuelheli is offline
Find More Posts by nofuelheli
fff> Fly Foam for Fun
nofuelheli's Avatar
Roanoke VA
Joined Sep 2003
I set mine up according to the hobby lobby suggestions. 2208/34 w/ jetti (or p10) and run the etech 700's 2s . Have a 3s 700 pack but it doesnt need it. Made my own motor mount (aluminum) instead of that heavy metal they give you in the axi mounting kit. The way it's made you do not need to use the liteply in the hobby lobby brushless conversion faq.
nofuelheli is offline Find More Posts by nofuelheli
Old May 01, 2004, 07:12 AM
TeamSME is offline
TeamSME's Avatar
Joined Jul 2003
Yah, I'm looking for insane power. Kinda like in the chipsledde video. But I don't want a heavy setup. I will also be flying this plane out doors because I have yet to find a good gym or place I could fly.
Thanks alot,
Sean Ellis
Old May 01, 2004, 10:58 AM
TeamSME is offline
TeamSME's Avatar
Joined Jul 2003
I finally ordered my shocky. Now I have to scrape together some money for the motor and lipos and esc.
Old May 02, 2004, 09:26 AM
TeamSME is offline
TeamSME's Avatar
Joined Jul 2003
I have my lipos lined up, I'm getting a 2 cell 830 apogee pack, and the axi 2208 34 when I get the money.
Old May 02, 2004, 11:45 AM
Agra, Oklahoma
Joined Feb 2000
You should be happy with that setup.
Keep us informed on how the build and flying goes!
Steve
Old May 02, 2004, 11:50 AM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
TeamSME:
I'm exploring the posibility of using a GWS IPS-Dual Brushed Motor, it's fairly light & should give plenty of thrust. Plus, I have an abundance of Brushed controllers & 2S Etec 1200-2S packs. I may give it a go in my Edge Shockie that is nearing completion. If I pick up a Dual, I will post the results here on Ezone.
-Mike-
mrebman is offline Find More Posts by mrebman
Old May 02, 2004, 02:11 PM
TeamSME is offline
TeamSME's Avatar
Joined Jul 2003
cool, thanks
HELP ME!!!< I think I'm getting addicted to cutting foam!!! slowflyer Foamies (Kits) 7 Feb 21, 2011 12:58 PM
Yippee! Okay, That's it ... I'm Getting the Shovel gregw Humor 2 Mar 28, 2004 03:49 AM
looks like i'm getting a piccolo, any advice? cheapflyr Electric Heli Talk 13 May 10, 2001 08:34 AM
I'm getting worried SchiessCo Electric Plane Talk 1 Apr 21, 2001 08:11 AM
