Old Apr 29, 2004, 11:25 PM
HavingFun2002 is offline
Find More Posts by HavingFun2002
HavingFun2002's Avatar
Reston, VA
Joined Feb 2002
Will I Fry My TP2100-3S?
I just install a Mega 15/16/3 I had lying around in my old Zagi, and I really would like to use my TP2100-3S to drive it. I'm using an APC 4.7/4.7 and I'm pulling about 17-18 AMPs.
It looks like I'm on the edge, and I was wondering if anybody had fried these packs at that AMP draw? I typically fly the Zagi at full throttle, most of the flights.
HavingFun2002 is offline Find More Posts by HavingFun2002
Old Apr 30, 2004, 07:34 AM
uglystick is offline
Find More Posts by uglystick
Arnold , Maryland, United States
Joined Nov 2002
I think it is really important to stay under the discharge rate that the manufacturer suggests.
Once you start to pull more current than the suggested amount, the pack voltage depresses. Sometimes to the point of triggering the low voltage cut off of the ESC.
So you end up with a poor performing battery pack, plus you run the risk of damaging a cell or two, which can cause a charging incident. ( cell burst or fire). It's just not worth the risk.
Unless you have the latest version TPs, yours can only be discharged at 6C. Thats only 12.6 amps. A lot less than the 17a, you expect to draw.
You are not on the edge, you are over it, unless you run at partial throttle only.
Irate 2600s would handle it though. 20 amps
uglystick is offline Find More Posts by uglystick
Old Apr 30, 2004, 09:39 AM
Reston, VA
Joined Feb 2002
I think you're right.
Yep. You are correct. I'm going to replace it with a Mega 15/16/4. With the same prop I should be right at 11A. Why take the risk?
"Irate 2600s would handle it though. 20 amps"
Who sells these?
Old Apr 30, 2004, 10:13 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.unipros.com/cbpsite/custo...ssion_id=91126
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 30, 2004, 10:16 AM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
I'm using an older 2100 TP 3S pack with a B20 15L in a ducted fan,.. 22 amps peak, just over 200 watts. That's above the manuf. specs, and they come out hot at the end of a flight, but I haven't puffed a pack yet. I use throttle a lot (this EDF has unlimited vertical, so you don't need a lot of full throttle ). Average 8 to 9 minute flights, indicating 6 to 7 C average. The new 1950 10C cells handle it constant, no problem.
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Latest blog entry: blog
Charlie Wang is offline
Find More Posts by Charlie Wang
Joined Dec 2002
New gen2 TP2100s is now under the aging process(20,000pcs), ready for sale in less than 2 weeks.
If you call Jason at Thunder Power(702-228-8883), he may arrange to sell you "0ne" preproduction pack TP2100-3S/12C to be deliver on monday.
Dimensions:20mm x 34mm x 98mm
weight: 4.5oz
continuos discharge current:25Amp
Short burst current: 40Amps
Regards,
Charlie
Charlie Wang is offline Find More Posts by Charlie Wang
Old Apr 30, 2004, 02:35 PM
Reston, VA
Joined Feb 2002
weight: 4.5oz
Regards,
Charlie
Looks like they are on the www.tppacks.com site now. Cool, I'll wait and purchase those.
Old Apr 30, 2004, 03:58 PM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
If you fly full throttle all the time, forget about 18a constant draw. If you could use throttle management you'd be good (my friend's himaxx setup pulls 18.5a but in flight averages much less...) and it works but the packs come out hotter than i would like..
headless is offline Find More Posts by headless
Discussion UGHH,I just ruined my TP2100 3s gen2? miamiquasar Batteries and Chargers 18 Jul 05, 2006 08:33 AM
Are my TP2100 3S packs unbalanced? Brill 1 Batteries and Chargers 4 Oct 03, 2004 11:00 AM
DYMOND SUPER TURBO on 75 AMPS?!?! WILL I FRY MY CHARGER? mike98624 Batteries and Chargers 10 Apr 12, 2003 02:23 PM
Will this fry my brushless controller? ControlFreak Power Systems 11 Mar 02, 2003 11:37 AM
Will I fry my esc 701 Super Jet Power Systems 3 May 18, 2002 09:50 AM
