Old Apr 29, 2004, 04:03 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
Xero-G Carbon Raptor E-Conversion
Here are some pics!
The frame kits are available from http://store.xtremercproducts.com/ and http://www.rchelisplus.com/
Street price should be right around $279. I had the aluminum motor mount made up from 1/4" stock. While it's not really heavy, it's way stronger than it really needs to be. The next version will be lighter.
I like the component layout and design of the frame set. It's a CCPM design with proper geometry for the pushrods, i.e. everything is exactly at 90 degrees so any kind of control interaction should be at an absolute minimum. The lower frames are 60mm wide and would allow even the older 7800 and 8000mah Thunder Power packs to fit within the frames. I'm not sure if this will be of any benefit but at least it's an option.
I'll try to keep adding to this as I progress with the refinement and development of my e-conversion.
ScotY is offline Find More Posts by ScotY
Old Apr 29, 2004, 02:21 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
looks good scot!
Ben74 is offline Find More Posts by Ben74
Old Jan 07, 2005, 01:49 AM
misskimo is offline
Find More Posts by misskimo
TeamTP,Minicopter,Spartan
misskimo's Avatar
Mississippi 31 years , Now Kotzebue , Alaska 12
Joined Apr 2001
Dang , man , you shoud have flown it before you sold it Scot , I have a top mount outrunner , but I could get a 24-4 for it and make that at work , looks great
thanks Tony
misskimo is offline Find More Posts by misskimo
Old Jan 07, 2005, 01:53 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , I will mount the batteries on the side , get them high as I can with out hitting anything , and also use the 90t modified gear I just made up useing a stripped out 85t and turning it down to fit a MA 90t ring gear , now I just need to do the math
Tony
Old Jan 07, 2005, 02:14 AM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
The "standard" Actro is going to be easier to mount, I think. There's no carbon up top where you'd want it to be to mount the heli version...unless you get really creative. I don't see any huge disadvantage to using the standard motor. If you go with this layout, you might want to consider turning down the frame spacers to bring the lower frames further in. It's probably a fair amount of work involved but not overly difficult. You'll have more room for batteries outside the frame since they won't likely fit inside. I think one 10s2p Lite Pro pack would fit right under the motor. Kinda low CG but easy to do.
Good luck and let us know how things progress!
Old Jan 07, 2005, 02:42 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
huh? man I just cant make up my mind , box , or 32-4 with the 90t main , or the 24-4 , huh?
better sleep on it
Old Jan 07, 2005, 03:08 AM
freezin Eskimo is offline
Find More Posts by freezin Eskimo
Freezin Eskimo
freezin Eskimo's Avatar
Eden, South Dakota
Joined Feb 2004
Okay after i got mine all built your tellin me i got take the OS 50SX-H out of there, and stick me a Actro Brushless in there! Okay im cool with that now where do i get a Actro Mount like that for my CCPM Frames?i got the Actro, and the pinion set up, now i just need the mount!
Karl
freezin Eskimo is offline Find More Posts by freezin Eskimo
Old Jan 07, 2005, 09:20 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , when I make mine , maybe I will make yours too
Old Jan 07, 2005, 11:28 PM
Freezin Eskimo
Eden, South Dakota
Joined Feb 2004
Right on! Sounds good! Ill sell the logo 20 then?
Karl
Old Jan 08, 2005, 02:08 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
For those interested, below are some shots of my XeroG-based Raptor. I cut off most of the front part of the "stock" frames, which aren't really needed. I also brought the outer/lower frames in 2mm on each side by making some new spacers that are 11mm instead of 13mm. These were made from 3/16" tubing, and as a result are a bit lighter than the provided solid machined pieces. The reason for doing this was so I could use some simple L-shaped adapter pieces for the v2 box that are made from 1/4" stock. The adapters bolt to the sides of the box, using countersunk screws, and the the adapters are attached to the outer frames at four points. The single 10s2p pack straps to the bottom of the box, and to the frames in the back.
Finally, until yesterday, I had the 1515-2Y (1100 kV...) in there with R30 86T/9T gearing. Performance, with this Pro Lite 10s2p pack, was about as good as I've ever seen, in a 600-bladed helicopter, and I've seen a few hot setups, I think. A video of Nick flying it the other day is here. While the raw power was very impressive, I know there's a bit more in the "tank", so I made one final change. () I got Al to send me one of his modded Raptor 60/90 main gears, that has 95T, and I put that in, and then swapped out the 2Y motor for a 1515-1.5Y (1350 kv...). This caused me to have to move the starter shaft bearing blocks, and the box/motor assembly forward a bit (you can see in the pics that I had to drill out new slotted holes...). Anyway, I know this is going to just create enough torque to rip the blades apart!
Here's the pics:
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jan 08, 2005, 02:42 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
hey , Man , that looks nice , save me one of those gear boxes ,
but i need to wait a while , christmas about broke me ,
Im sending you a PM in a minute
Tony
Old Jan 08, 2005, 02:55 AM
misskimo is offline
misskimo's Avatar
Joined Apr 2001
would that happen to be the titainum motor shaft in there ? if so how is it holding up ?
Old Jan 08, 2005, 05:37 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Gary – that’s going to be a real winner. I am looking forward to a conversion kit for “The Box”. Do you think you will have a kit out sometime this spring?
RC
RC Man is offline Find More Posts by RC Man
Old Jan 08, 2005, 09:28 AM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Tony -- Yes,this is using one of the titanium shafts I got from you. I'm getting them cut into several sizes this week and will start offering them as options with the kits this week.
The "stock" Raptor v2 box kits are available now. They will work with either the v1 or the v2 version of the Raptor frames. I'm hoping to have a modified version of Al's UE framset available by the MWE next month. This mod for the XeroG was a "one of", and I don't know if I'll do an adapter set. Depends on how many of these sets are out there.
-- Gary
Old Jan 08, 2005, 03:38 PM
Freezin Eskimo
Eden, South Dakota
Joined Feb 2004
So i might be able to get one for this?
For Sale FS: Raptor E-conversion, CCPM conversion & Front Camera Mnt chilipepper Aircraft - Electric - Helis (FS/W) 0 Feb 28, 2007 04:44 PM
Sold Xero G Carbon Frame, Actro 24-4, custom mount plasmaman Aircraft - Electric - Helis (FS/W) 6 Sep 23, 2005 07:26 AM
Help! Where to buy "V2 BOX" for Raptor e-conversion if outside USA r40334 Electric Heli Talk 4 May 14, 2005 06:33 PM
Rappy xero G carbon fiber heli F/S 650 shipped misskimo Aircraft - Electric - Helis (FS/W) 4 Feb 12, 2005 05:14 AM
Rutan Long Eze G To E Conversion Mark Haigh Sport Planes 12 Nov 04, 2004 12:18 AM
