Joined Oct 2002
96 Inch OLD TIMER Project Status!
Amazing Project! Recall that 96 inch OLD TIMER PROJECT?
Well, looks like he maiden it this past weekend and here's some pic's of the finish project/model ! AMAZING and POWERED by the DEWALT CORDLESS DRILL "BRUSH" MOTOR !Way to GO! http://www.rcgroups.com/forums/showthread.php?t=228709 http://www.rcgroups.com/forums/showt...72#post2172172 |
Toby |
Joined Oct 2002
Don't forget you flying buddies over CARLISLE FIELD (a.k.a., HOME DEPOT) so, most of us can be your experiementation customers. Having a new product to be monitored close to home is very helpful since we can meet and log flights, measure AMPs, WATTS, Prop size/pitch/type and provide you with product data such that you can use it for recommended application for prospective customers and issue warrantee limits for the motor. Not to mention the appropriate partner for Electronic Speed control for the best efficiency and modulation for your new motor. Let me know if you are looking for volunters to provide historical data on the first new motors you may have on hand. I will BUY it off of you and be glad to keep track any parameter you like in a log book. Carlos
Don't worry carlos, i don't think anyone can ever forget you. The one thing that is holding us back is a shippment of shafts, after those come in the motors can be built. although i guess in the mean-time a GWS shaft will work. do you want to build some carlos? (and others) it is a time consuming and somewhat frustrating process to wind your own (at least the first time). i do not have much time to build the actual motors, since i will be makeing the parts, but if you would like an early crack at the kit, i will see what i can do. There is a tutorial on www.gobrushless.com that will give you an idea of what is involved. you will have to get your own stators, magnets,and bearings from gobrushless for the time being. i am currently only makeing the cans for the double and tripple stack 22.7mm stator. I know brad is in . Chuck, did you ever make your own motor?I will make it to edwards once the winds calm down to maiden my turbo hawk-p (who knows when that will be...). i may also stop by Carlisle, but that nice concrete slab at edwards looks much safer for my plane. and the lack of motocrossers is a pluss. Toby |
Carlos, Brad, and others, here is what you need.
I would suggest a double-stack as your first motor, a tripple stack is harder to wind. you should get better than speed 350 performance from a double stack, depending on your wind. From www.gobrushless.com 2 - 22.7mm dia stator (3 for a tripple stack) 2 - 6*3*2.5mm bearings (or you can use GWS bearings) wire - i suggest 26ga as a good starting point for torque, if you want speed go for the thinner 28ga ,or get lots of different gauges and experiment. radioshak sells some (that is what i have used) and Skycraft surplus has a great selection. gobrushless does have "newbie wire" in 3 different colors. for magnets go here: http://www.engconcepts.net/Magnets/P...x_Magnets.html 12 -10*3*2mm for doublestack (50 for $20) 12 - 15*4*2mm for tripplestack (50 for $40) now you just need a 3mm shaft, from a broken CD-rom drive or you can use a GWS shaft, but if it bends, it will be a pain to replace. Let me know when you get this and i will help you out the rest of the way. Toby |
| Thread Tools | |
| Orlando E-Zone Squad Version XV | MattVernon | Club Talk | 3089 | Jun 26, 2005 05:47 PM |
| Orlando E-Zone SQUAD Version- Niner. (V-1 Started by RMason they think!!!) | fishdeth | Club Talk | 508 | Jan 04, 2005 12:15 PM |
| Orlando E-Zone SQUAD Version-XIII. (V-1 Started by RMason they think!!!) | guapoman2000 | Club Talk | 507 | Nov 19, 2004 12:01 AM |
| Orlando E-Zone SQUAD Version-XII. (V-1 Started by RMason they think!!!) | fishdeth | Club Talk | 501 | Oct 04, 2004 08:07 PM |
| Orlando E-Zone SQUAD Version-X. (V-1 Started by RMason they think!!!) | Don Sims | Club Talk | 511 | Apr 28, 2004 03:19 PM |
