Old Jan 02, 2002, 01:15 AM
MiL is offline
MiL
Find More Posts by MiL
MiL
Corvallis, Oregon
Joined Jan 2002
House of Balsa 1/2A Stealth Sport --> EP?
Hi, i'm an intermediate level glow pilot and am looking for a small, cheap, and moderately aerobatic EP plane as my first electric project. I was wondering if anyone has converted the House of Balsa 1/2A Stealth Sport kit to electric power. I would imagine that it has been attempted before and was just wondering if anyone had any feedback to offer me on the topic or any other kits to suggest.
MiL
**EDIT** I should also mention that I would like a plane that can be flown in a relatively confined area. I'm hoping to fly at the elementary school about a block from my house. There is a baseball diamond with a sizable field next to it, i think it should be ample room for a reasonably small and slow flying model.
MiL is offline Find More Posts by MiL
Old Jan 02, 2002, 10:46 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Mil, Welcome to the Ezone! I can't comment on the Stealth kit as I have no personal experiance with one. It should work out quite well if given enough power. How big is the plane and how much is it supposed to weigh when finished? This will help us to make suggestions on the power source.
GregG is offline Find More Posts by GregG
Old Jan 02, 2002, 04:08 PM
MiL is offline
MiL
MiL
Corvallis, Oregon
Joined Jan 2002
Here is the Stealth Sport page on Tower's website: http://www2.towerhobbies.com/cgi-bin...1&I=LXM401&P=0
And here is the HoB page: http://www.mag-web.com/rc-modeler/hobnew/12a.html with pretty much all the same info.
It's an all balsa, elevator and aileron controlled plane.
the basic stats are:
wingspan: 32"
Wing area: 252 in.^2
Wt. with radio 18 to 22 oz.
Wing loading 11.5 oz./sq. ft
Engine reqd. .049 Dragonfly or Blackwidow
Here's a pic
The other thing i'm considering is maybe a plane large enough that i would not have to buy micro servos and reciever but that is still within the 6-8 cell range.
Thanks again,
MiL
Old Jan 03, 2002, 04:08 PM
Gonflyin01 is offline
Find More Posts by Gonflyin01
Toledo Ohio, USA!
Joined Dec 2001
I would not reccomend the stealth as an aerobatic model. it is not powered enough unless you use more than a spd.400 it would fly, pretty nicely also, but it would not be aerobatic. with a Speed 480 it would make a great plane tho!
Gonflyin01 is offline Find More Posts by Gonflyin01
Old Jan 06, 2002, 09:14 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
This plane is hell on wheels with an .049 in it, but you'll have to make come concessions to get performance out of it. The Stealth is one of those lightly loaded airplanes that 'flies' rather than muscles and hustles around the sky. She's a real sweetheart!
The original is intended for standard servos etc., but it also had a reed valve .049 motor with an integral tank. The motor helped make it possible to have big, cheap radio gear and still have a light wingloading. You will want to use S-80 servos (under $20), a Rocket 400 with a 2:1 gearbox, 8-4 to 8-6 prop and a 15-20A speed control.
With 252 sq. in., you could afford to be pretty heavy but the lighter the better. You could get great vertical if you kept it under 16oz, but even 20 wouldn't be heavy.
You'll be learning to build differently with electrics too. Since there's no vibration or oil, you can build much lighter and with less glue and still have a very strong airframe.
Have Fun!
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Old Apr 22, 2004, 07:31 PM
SQUEEKS548 is offline
Find More Posts by SQUEEKS548
Joined Apr 2004
Hey I just got a Stealth Sport and was wondering if I put a OS .10 in it if that would be reasonable. You guys seem to know alot about this. Thanks Sean
SQUEEKS548 is offline Find More Posts by SQUEEKS548
Old Apr 11, 2008, 02:15 PM
Geo1 is offline
Find More Posts by Geo1
Geo1's Avatar
Joined Mar 2008
Hi I'm trying to do this anyone have more info
I have the gws 400 with 2:1 gear brushed motor
a 480li esc....
now what size of battery and type ?
prop is a 8-6 ..
Geo1 is offline Find More Posts by Geo1
Old Dec 20, 2009, 04:38 AM
Jaspur_x is offline
Find More Posts by Jaspur_x
Somerset Pa
Joined Dec 2009
Does anybody know if this kit is still available?
Jaspur_x is offline Find More Posts by Jaspur_x
Old Dec 20, 2009, 12:46 PM
GD5015 is offline
Find More Posts by GD5015
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
Here ya go.
http://www.houseofbalsa.com/store/st...azLsj81WI1z7M6
John
GD5015 is offline Find More Posts by GD5015
the simplest...STEALTH SPORT>>> gpw Foamies (Kits) 255 Sep 02, 2010 11:36 AM
FS: House of Balsa 1/2A Chipmunk Conversion. genovia Aircraft - Electric - Airplanes (FS/W) 12 Mar 01, 2003 10:05 PM
House of Balsa 1/2A Stealth Sport mt_100 Electric Plane Talk 1 Jul 30, 2002 05:10 AM
House of Balsa 1/12 P-51 as a Sloper? Foxtrot Electric Sailplanes 9 Jul 12, 2001 10:54 AM
