Old Jan 01, 2002, 11:50 PM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
Question about Carbon Fiber Rods (Soarstar Landing gear)
I have not had any experience with carbon fiber rods.
Are they really hard to bend? My soarstars landing gear rod is always bending, would be nice to replace it with something that is stronger.
joemi is offline Find More Posts by joemi
Old Jan 02, 2002, 01:43 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
Hi joemi.
CF rod won't bend and hold a set, but it will snap when it gets to a rigid mounting if you "land" hard enough.
I'm using 0.08" dia. and 3 1/2" length on my Tiger Moth. It snapped off once, but that was more of a crash than a landing. Seems to have just about the right spring for normal landings.
RB
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Jan 02, 2002, 08:19 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
After snapping 2 sets of CF LG on my Hissy-Fit, just landing in grass and having the gear snag, I went back to piano wire, and like it better, due to the forgiving nature. Sure it might bend or flex, but that's better than snapping....
my $.02
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 07, 2002, 05:58 AM
YZYgold is offline
Find More Posts by YZYgold
Singapore Holland Rd
Joined Mar 2002
My landing gear never bended or snaped even when i did a full throttle crash cause i was trying to do inverted flight.
Only the whole fusalage came apart a bit of the wing but im flying again wit my handy 5 min epoxy
YZYgold is offline Find More Posts by YZYgold
Old Mar 07, 2002, 09:09 AM
Newark, DE USA
Joined May 2001
That's a good way to save your landing gear.
I'll keep it in mind.
RB
Old Mar 07, 2002, 11:31 AM
tom_yellowblue is offline
Find More Posts by tom_yellowblue
Sunnyvale, CA
Joined May 2001
I use 0.08" CF rod landing gear on my Tiny. No problems so far, but I haven't really stressed them.
genebond, do you remember what size rods you were using?
tom_yellowblue is offline Find More Posts by tom_yellowblue
Old May 09, 2002, 02:16 PM
freq is offline
Find More Posts by freq
soft yummy goodness.
freq's Avatar
North Jersey, USA
Joined Oct 2001
I replaced the stock wire axle on my Soarstar with same diameter CF rod. One side snapped at the junction to the wood block on the 4th landing. Landing was a touch on the hard side, but not excessively so, IMO.
I've since gone back to the original stock wire axle. As genebond said, better to bend than break.
I'm considering moving up to a thicker diameter CF rod eventually, but to do that, I'd have to:
1) route a wider groove in the wood block axle mount
2) ream out or replace the wheels
3) buy new wheel collars
4) replace the spacer tubes
5) ream out or replace rubber grommets for wing struts & floats
Worth it? We'll see....
Anyone know where to get replacement rubber grommets? I just know I'm gonna lose a few of 'em.
-chris
freq is offline Find More Posts by freq
Carbon Fiber Rods rplourdejr Scratchbuilt Indoor and Micro Models 13 Apr 08, 2011 12:34 AM
Question Urgent question about a Carbon Fiber rod through Fuselage eckcessive Electric Plane Talk 9 Nov 09, 2006 10:01 AM
Discussion Question about Carbon Fiber... Pshaw Micro Helis 14 Jan 09, 2006 12:17 PM
IFO question about the Carbon Fiber rods 1Way Scratchbuilt Indoor and Micro Models 2 Apr 24, 2004 03:46 AM
Source for Carbon Fiber rods Twmaster Parkflyers 11 Sep 27, 2001 12:23 AM
