Old Apr 26, 2004, 07:34 PM
bronco is offline
Find More Posts by bronco
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
Bristol f2b
thought i would post some pictures of my latest project a Bristol f2 b from my own plans, these photos are from two weeks ago , the plane is now close to being done, i"ll post more pictures soon . i just had to post them now before peter rake beats me to this one. specs are 35 in span ,344 sq.in. 18 to 20 oz wt , geared sp 400 . i designed it for 7 to 8 cells but i may use lipos instead.
bronco is offline Find More Posts by bronco
Old Apr 26, 2004, 07:39 PM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
i will have more pics tommorow. i tried to keep thing simple but its taken on a life of its own . the bottom wing is mounted below the fusalage on unscale pylon for the sake of keeping it simple.
Old Apr 27, 2004, 07:31 AM
Wolpertinger is online now
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Very, Very nice. You will get more scale points with another wing, though Seriously though, It really does look good. Nice Work.
Wolpertinger is online now Find More Posts by Wolpertinger
Old Apr 27, 2004, 01:23 PM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Looks great. Will you be offering the plans?
Jim
JIMA is offline Find More Posts by JIMA
Old Apr 27, 2004, 04:02 PM
Redbaron25 is offline
Find More Posts by Redbaron25
North East England
Joined Feb 2004
Nice looking model.! There's not that many plans for electric Bristol Fighters about, so I'm watching your progress with interest - good luck!
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Apr 27, 2004, 04:04 PM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Looks nice, but wasn't the F2b a BIplane?
GordonTarling is offline Find More Posts by GordonTarling
Old Apr 27, 2004, 04:32 PM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
ok ok indeed it was a 2 winger ,i would like to offer the plane as a plan any ideas on how to go about that,perhaps a friend who has a web site ?(hint hint wink wink ....dean?)any way here are some more pic s ,still needs the iterplane struts and some details added ,also better wheels.
Old Apr 27, 2004, 05:08 PM
JIMA is offline
JIMA's Avatar
Joined Jan 2003
Here is a place you can post the plans. http://plans.rcmodell.hu/
Jim
Old Apr 28, 2004, 03:52 AM
Joined Mar 2001
Bronco - I was only teasing. That now looks a lot more like an F2b and is looking good.
Old Jun 21, 2004, 01:03 PM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
it's been awhile but i finaily finished my bristal and it's had it's first flight that went well after 3 ground loops first . trying to take off from a muddy baseball infield does have it's share of problems.take off run of about 30 feet resulted in a nice climb out with a little down trim needed for level flight. left turn right turn no problems then a power off stall again no trouble. i then flew a couple of laps of the field and it was getting near time to leave for work, so i lined up for a landing on the in field again ,running out dirt i stalled it a few inches up and it plopped down with no roll out, not a scale type landing but it was on the ground in one piece . here are the finished specs 35.5 inch span ,17,5 oz wt ,3 channel funtion .a graupner 3321 motor geared 2.5 to 1 a top flight 9x7 wood prop and a 830mah apogee lipo cell. so far only the one flight, weather around here has been really bad ,also here are a couple of pics, sorry no in flight pics,i was alone at the time .Bruce
Old Jun 21, 2004, 01:11 PM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
doh
Old Jun 21, 2004, 01:13 PM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
1 more
Old Jun 21, 2004, 02:28 PM
JIMA is offline
JIMA's Avatar
Joined Jan 2003
Sweet!!!
Jim
Old Jun 23, 2004, 12:34 AM
sparkinwheels is offline
Find More Posts by sparkinwheels
sparkinwheels's Avatar
Cumbria
Joined Apr 2003
Very nice job, my favourite WWII aircraft good luck with your plans mate.
I have had the prototype plan off Pete for his F2b for about 6 weeks, (only been at him for 12 months) so it will be nice to compare build concepts between the 2 plans. I'll not be able to start it for a few weeks because of show comitments. I will be including ailerons in the build tho'. Ali has these amazing 'Mighty Atom' servos, 4.4 gms with 1 Kg torque plus he is stocking nice & light silicon wire including servo cable of different weights!
I like your colour scheme and you certainly kept the weight down, I take it that the Wooden prop was not replaced by other type for the flight mate?
All the best
John
sparkinwheels is offline Find More Posts by sparkinwheels
Old Jun 23, 2004, 08:39 AM
bronco is offline
zen pilot
bronco's Avatar
milwaukee WI USA
Joined Jun 2000
The f2b is one my favourites too. though not most effecent props to use .it did fly with it.How does my version compare in size to Mr, Rakes ? . I would like to make my plan avalable for free as a DXF file but my cad programe will not let me convert it for some reason . Any one care to try and convert it to dxf and send it back to me? I need to finish cleaning up the plan first but the service would be greatly appreciated. My next project is going to be the CAPRONI Ca 33. any interest in this 3 engined beast? regards bruce
Build Log Bristol F2B Build Tim Farrar Scale Fuel Planes 719 Jan 29, 2012 06:15 PM
Discussion Makeing a scale Bristol F2b exhaust Tim Farrar Fuel Plane Talk 13 Dec 17, 2008 09:39 PM
Sp280 powered Bristol F2b flies Looooeeee! Scale Kit/Scratch Built 6 Sep 23, 2007 02:55 PM
Question Scaling up the Flair Bristol F2b JCHutch Scale Fuel Planes 2 Sep 19, 2007 05:25 PM
