Old Apr 26, 2004, 02:42 AM
sayno2glo is offline
Find More Posts by sayno2glo
I plan to take over world
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
Hacker 9-cell motor with 7 cells...what prop?
Hi,
Seeing how fast plane Tuomas has I have to do something to keep up with him So I'm sure someone has already tried a 9-cell motor (I have Hacker 6L) with 7 GP3000's. Limiting factor most likely is the controller 70-pylon but I might change it to 105. So would CAM 5,2x5,2 be OK with the older 70-pylon controller which I believe can handle 85A max? The problem is that I'm busy studying and next chance to fly is in the competition so the setup should be proved to work
/Antti
sayno2glo is offline Find More Posts by sayno2glo
Old Apr 26, 2004, 06:45 AM
Sebastien is offline
Find More Posts by Sebastien
Brussels, Belgium
Joined Nov 2000
I fly the aluminium 6L with 7x GP 3000 and APC 5x5 prop ( I also tested the 5,5x4,5, but it gives less speed ) it is not as fast as the 9 cells carbon setup in the firsts laps, but a lot faster on the 2 or 3 last laps ... thz controller is my old kontronik 3SL...
Sebastien is offline Find More Posts by Sebastien
Old Apr 26, 2004, 06:58 AM
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
Thanks Sebastien! I knew that 5x5 would be ok but I'm not sure about 5,2x5,2 which has actually 5,5 pitch. Have you ran your batteries hot like 60 centigrade? Low tempereture will slow you down in first lap. Is that 3SL a 70 amp controller?
/Antti
Old Apr 26, 2004, 03:20 PM
Brussels, Belgium
Joined Nov 2000
Yes I run on hot batteries ( 70 ) the controller is the old 3SL pylon , and I get around 135 seconds of full throttle with the APC 5x5 wich is too much...
For Sale Hacker B50FAI 10 cell motor with 6.7:1 gearbox Price lowered neilo Aircraft - Electric - Power Systems (FS/W) 1 Jan 10, 2007 09:42 PM
Motor with 7-cell battery jk123 Electric Power Cars 1 Jul 22, 2004 11:31 PM
FS: Hacker B40-FAI,9 cell motor/controller Jackspt28 Aircraft - Electric - Airplanes (FS/W) 3 Jan 03, 2004 04:19 PM
IPS-A Motor with Litestick/Duskstick? What prop do I use? mrebman Power Systems 1 Dec 01, 2003 11:31 AM
Mega 22/20/4 and 10 cells...What prop??? Tim H. Sport Planes 8 Jul 12, 2002 08:17 PM
