Old Apr 26, 2004, 01:42 AM
RockyTse is offline
Find More Posts by RockyTse
Joined Apr 2004
High KV or Low KV
I intended to purchase a 2015 series Himaxx and gear it down, to be used for APC 7 x 5 at arround 13000 rpm, at 3 cell Li-ion. assuming 10V underload, which to achieve 8 amp max output current.
2015-2700, using 2:1 gear ratio down to 13500 rpm.
2015-5400, using 4.4:1 gear ratio around 12300 rpm.
Which set up is better in term of efficiency? (longer flight time/less current draw) or if the set up is no good.
Please give advice.
RockyTse is offline Find More Posts by RockyTse
Old Apr 26, 2004, 06:56 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
High kV, 4.4:1..
..a
Old Apr 26, 2004, 09:51 AM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
What Andy said. The higher Kv motor has lower internal resistance. Until you're up at a voltage where max RPM is an issue, it's usually better to go with the higher Kv motor geared deeper.
Darren Hintze is offline Find More Posts by Darren Hintze
Discussion Question running high V on low Kv motors (himax, 2025 series) badinstincts Power Systems 20 Mar 08, 2006 05:26 PM
Discussion High $$$ 20C or low $$$ 12C batteries Milton Batteries and Chargers 11 Jan 08, 2006 05:46 PM
Himaxx 2025 -4200 High Pole or Low Pole Count Baracus Castle Creations 2 Dec 02, 2004 07:28 AM
High Kv small pinion vs low Kv large pinion? Nicke Power Systems 13 Oct 16, 2003 02:38 AM
