Apr 25, 2004, 07:31 PM
United States, MI, Holland
Joined Dec 1996
Something I can't live without
It's rare that I come accross something in this hobby that I just can't live without, but I did.
After hearing from a few of the old time modellers at the LHS I decided to pick up an Ace Add-A-Trickle for my radio charging. I own a Hitec Eclipse with the stock pack replaced with an 1800mah NiMh pack and always find it to be low on charge when I need it.
After buying this the install was simple. Just cut the wires on your stock radio charger and put this inline. Hook your radio up to charge like you normally would and you have two options. The first is to press the charge button which will do a 16 hour charge at the normal rate and then switch to the trickle rate. Or you can start the trickle rate and let it go indefinately. The trickle rate is 110th of whatever your chargers normal rate is. In the case of my Hitec 55mah for the default charge and 5.5mah for the trickle charge.
The device is made to keep your radio on charge indefinately, so that is what I do. After a week of using this I have never had a case when my radio was not charged when I need it to be. I have also noticed that my radio batteries maintain their charge better than before and last a bit longer, most likely because the very slow trickle rate keeps the cells well matched and charged.
For everyone out there that has the same problems as me, radio is always dead when you need it to be, get one of these and it will go away.
Ace Add-A-Trickle available from your LHS, I got mine from New Creations for around $25.00 plus shipping. Well worth the price.
