Apr 26, 2004, 12:36 PM
Valencia, CA
Joined Oct 2002
Package Delivery System
The Tomahawk actually has a variant that can dispurse submunitions on little parachutes for missions such as runway cratering. Fedex could do mass deliveries of packages that are a little less lethal.
We used to have great luck with profile balsa gliders of the Tomahawk, and the engine is located in the very back, just where it should be for an EDF, so it should make a good model. Control of the full scale Tomahawk is with a rudder and elevons, which could be easily done with a mixer and the long nose should help with balancing out the CG.
You may need to use a bungee for launch -- or if you are really ambitious, fold the wings and use a launch tube and booster "F" series rocket motor. With no control surfaces on the wings, they could be folded in a model, but that adds design complication, not to mention weight. If you do fold the wings, you better manually release them with another servo, because they shouldn't be opened until the bird has slowed a little and is in a less vertical attitude.
Pete G.
