Old Apr 23, 2004, 04:10 PM
EGB is offline
EGB
Find More Posts by EGB
EGB
Joined Jan 2003
Pixie20P cut-off and throttle range with a Hitec Focus 3 radio.
This may be a stupid question so forgive me for asking. I have a Hitec Focus 3 radio and have been setting it up with my Pixie-20P controller. Using the Pixie-20P default settings with a 300mA/7 cell battery pack in a GWS tigermoth I only get the throttle lever to about 1/2 way before the motor cuts out. This being my first electric plane makes it difficult for me to say if the motor has reached its peak output, but I am assuming so. I have not flown this plane as of yet (working on the final setup). My questions are 1st is this typical for throttle travel on the Hitec transmitter when running electric planes? And if not does the motor shutoff indicate that I am reaching cutoff voltage? I am concerned that I will be inadvertantly shutting the plane down during flight if I should move the throttle lever past the mid-way mark.
EGB
EGB is offline Find More Posts by EGB
Old Apr 23, 2004, 06:09 PM
mike50 is offline
Find More Posts by mike50
mike50's Avatar
Rochester, MN
Joined Jul 2003
It sounds like you are drawing enough current to pull the battery below the cutoff. On my Pixie-20P the cutoff voltages were not correct. Due to part tolerances, setting the cutoff at 6V actually caused it to cut off at 7.2V. I just programmed it to cutoff at 5V and now it cuts off nicely at 6V.
See this thread
http://www.rcgroups.com/forums/showthread.php?t=167419
mike50 is offline Find More Posts by mike50
Off Site Wild Wing with Hitec Focus 3-CH Radio, RX, Zagi ESC, Servos, Motor, Prop & 3 Batts Dampy Aircraft - Electric - Airplanes (FS/W) 3 Apr 01, 2007 10:22 PM
EBAY Hitec Focus 3 SS Radio WITH RECEIVER AND CRYSTALS FOR ZAGI baro99 Aircraft - Electric - Airplanes (FS/W) 0 Oct 09, 2003 11:09 AM
Brand new Hitec focus 3 radio With nicads--SOLD Steve H. Aircraft - Electric - Airplanes (FS/W) 2 Jun 08, 2002 11:13 AM
Wanted Hitec Focuss 3 Radio with Small Rec. & Servo's ROCKKZ Aircraft - Electric - Airplanes (FS/W) 0 Aug 03, 2001 05:19 PM
Fma mini 20 with Focus 3 radio Linear throttle not! Rekit Electric Plane Talk 11 Jul 01, 2001 08:48 AM
