Jan 01, 2002, 08:53 AM
United States, CT, Enfield
Joined Nov 2000
I built the S400 Shrike. Fast, great flying plane once balanced properly. I originally balanced the plane per the plans, but after 2 handlaunch attempts the plane was uncontrollable and went right into the ground both times. Moving the battery to move the CG forward about 3/16" helped a lot. The plane was now a fast stable flier, and the handlaunches were very easy. A bungee launcher is totally unnecessary. Once you get it balanced and flying well mark the battery position carefully, as this plane is very CG sensitive.
My Shrike had a 6v S400, a 6x3 Graupner folder, and 7 and 8 cell 600 batteries. Hitec 555Rx, and S-81 servos.
As far as the spars go I trimmed the forward and rear balsa spars flush with the fuselage inside walls, and left the main spruce spar intact. You mention the wing loads being carried by the sheeting and this is true, if the sheeting is properly secured to the fuselage sides. I trimmed the covering and squeezed a bead of epoxy all around the outside wing/fuselage joint after covering, and forced it in with an alcohol-dampened finger.
I put the aileron servo behind the main spruce spar, and the elevator servo was laid down on its side at the rear of the fuselage behind the aileron control horns. This set-up keeps all the pushrods very short. I also attached the Rx to the underside of the top hatch with velcro, this leaves a large space for the ESC and battery up front.
Good luck!
