KDE Direct XF UAS 75HV+ esc
Electric multirotor series
A new esc designed for heavy-lifting applications
KDE Direct has introduced a brand new esc designed and build specifically for heavy-lift and industrial UAS applications. The XF UAS 75HV+ is compatible with 3s up to 12s LiPo packs and uses a proprietary algorithm with a 600hz refresh rate for instantaneous response times. The esc is tuned specifically for KDE Direct XF multirotor motors and no throttle calibration is required (on most applications).
CLICK HERE for more info on the KDE XF UAS 75HV+
Specs:
Refresh Rate: 600 Hz (50 - 600Hz Adaptive)
  • Maximum Current: 135 A (5s Burst)
  • Maximum Power: 5,995 W (5s Burst)
  • Continuous Current: 75+ A
  • Continuous Power: 3,330+ W
  • Maximum Efficiency: > 98%
  • Voltage Range: 11.1 V (3S) - 44.4 V (12S)
  • Internal BEC: None (Opto-Isolation)
  • Maximum RPM: 240,000 rpm (2-Pole)
Old Aug 24, 2014, 10:09 PM
waladi is offline
Find More Posts by waladi
Learn to fly with thumb..
Indonesia, West Java, Depok
Joined Aug 2012
600hz... interesting to know how this can handle U8 135kv even lower..
waladi is offline Find More Posts by waladi
News The KDE Direct XF Multi-Rotor Brushless Motors Sleepyc Multirotor Talk 95 Jun 26, 2016 01:52 AM
New Product KDE Direct UAS Multi-Rotor ESCs Garret H Multirotor Electronics 1 Jun 22, 2014 09:55 AM
News KDE Direct Performance Boom Support Jim T. Graham Electric Heli Talk 0 Nov 13, 2013 10:46 AM
Sold KDE Direct 700XF-495 High Performance Brushless 700/800 Class Motor (495kV) Mike Fortune Aircraft - Electric - Power Systems (FS/W) 0 Nov 04, 2013 07:16 PM
Sold KDE Direct 700XF-495 High Performance Brushless 700/800 Class Motor (495kV) Mike Fortune Aircraft - Electric - Helis (FS/W) 0 Nov 04, 2013 07:15 PM
