Florida and Massachusetts
Joined Apr 2004
The filing made a big difference,especially the turning stabilizers on both sides. The 1" hole over the carb made a noticable difference also. It went fast before the changes but now it literally screams. Salt water has more bouyancy and that may contribute to the speed also, I am not certain on that one.
Running in salt water has it's dangers, primarily corrosion and care must be taken afterwards to clean it well. I use a bottle of water to back flush the cooling system then I run some WD-40 through it also. I changed as many screws as possible to stainless, wash it down after each use and then coat everthing with WD-40. I pull the driveshaft out after every couple of uses, clean and grease it. The only thing I am apprehensive about is the pull starter. I have flipped the boat a couple of times and I am sure salt water got into that area. The minute I have any problem I will pull that off, clean it up and spray it with WD-40 also. |
| Thread Tools | |
| Nitro Hammer | MattBar313 | Dock Talk | 9 | Sep 14, 2008 04:13 PM |
| FS P40 Engine Swap | clarock | Foamies (Kits) | 0 | Mar 24, 2004 11:46 AM |
| TM Engine swap | fifer | Parkflyers | 5 | Apr 25, 2002 07:52 AM |
