Old Apr 20, 2004, 11:30 AM
tailwind76 is offline
Find More Posts by tailwind76
regina canada
Joined Feb 2004
delta wing cg???
Hey
how do i calculate the cg of a delta wing aircraft?
i know convential is 25 -30 %
what is delta??
trent
tailwind76 is offline Find More Posts by tailwind76
Old Apr 21, 2004, 12:50 PM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
It has been asked and answered. Do a thread search.
Ollie is offline Find More Posts by Ollie
Old Apr 23, 2004, 10:34 AM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
I must apologise for my short answer. Although I know I have answered this question several times, I could not find them using the search function. So, here is a detailed answer:
The CG location affects three things. They are control responsiveness, pitch stability and pitch trim.
Stability is the tendency to return to a trimmed flight atitude and airspeed after a disturbance such as a gust or abrupt return of elevator to neutral. The more forward the CG the faster the plane returns to the trimmed flight condition. As the CG is moved aft, it will come to a place where the time to return to the trimmed flight condition is infinite and in fact, there is no longer a trimmed flight condition and the plane goes where it is pointed after the controls are neutralized or the gust passes. This is the point of neutral (zero) stability also called the neutral point. If the CG is moved aft of the neutral point, the plane diverges from its flight path and becomes unstable. A slightly unstable plane can be controlled by a pilot with quick reflexes and intense concentration but as the CG is moved farther aft, the plane becomes uncontrollable.
If the plane is a pure delta with a triangular wing planform and no canard surfaces or horizontal tail surfaces, then the neutral point is at the wing's aerodynamic center and the CG should be located about five to ten percent of the mean aerodynamic chord (MAC) ahead of the neutral point. The Aerodynamic Center (AC) of the wing is located at 25% of the MAC. The MAC is the chord through the center of area of half the plan form. In the case of a triangle, the center of area (centroid) is at 1/3 the semi-span from the center line. Therefore, the MAC is 2/3 of the root chord. For stability the CG should be 5 to 10% of the MAC ahead of the AC.
If you find this confusing, then give me the root chord measurement along the center line of the plane you are interested in and I will calculate the CG range and its location for you.
Old Apr 30, 2004, 02:23 PM
TheAeronut is offline
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
Ollie could have put it a bit more simply....
25% MAC is at 50% of the root chord on a full (not truncated) delta. Balace your delta No farther aft than 50% of the root chord, and preferably start about 40% and expect it to be just a little nose heavy. If the front end of the delta is truncated, simply project the leading edges out to where they intersect and use that as your root chord for balancing purposes. This general method will work alright unless the design has a significant truncation of the root leading edge or the wing tips.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Help! Delta wing CG without the Canards?? finishman2000 Modeling Science 15 Jul 25, 2006 04:39 PM
Help! Homebuild- Delta wing- CG? flight help ? advice needed.. maiden liljoe Foamies (Kits) 12 Mar 04, 2006 04:57 PM
Delta wing CG question rcnutt Foamies (Kits) 7 Nov 22, 2005 07:01 AM
Delta wing CG - how?? DaleM Flying Wings 7 Aug 14, 2004 11:04 AM
Question Delta wing CG Whereabouts? Claude G. Vest Fuel Plane Talk 2 Sep 11, 2003 10:41 AM
