This thread is privately moderated by Tahoe Ed, who may elect to delete unwanted replies.
Old Aug 10, 2014, 10:20 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Landing Gear Reset S800
I had to reset the landing gear. If you look around and follow the wires coming from each leg, you will see they plug into a R & L and there is an IN on a small block. Next to the IN is two little holes. The one closer to the L & R has a little button inside the hole. the next one to the right of that hole is a light. It's likely that it isn't showing any colour.
This fix will take two people.
1. Make sure the gear switch is in the DOWN position
2. With the power off. use a small screwdriver or paper clip and push in the button.
3. Set up the drone so that that the landing gear aren't touching the ground. I rested two of the arms on a desk and supported the drone via one of the other arms. THEN...
4. Push the button and hold it there while the other person plugs in the batteries.
It should go through a reset and then you will see the little light come on. You should be back in business! Try the landing gear lever and with any luck you'll be back in business.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Sold S800 Landing Gear $145.00 hadawayj Aircraft - Electric - Multirotor (FS/W) 0 Dec 14, 2013 07:49 AM
Sold S800 Landing Gear hadawayj Aircraft - Electric - Multirotor (FS/W) 2 Dec 10, 2013 05:02 PM
Sold S800 Landing Gear hadawayj Aircraft - Electric - Multirotor (FS/W) 5 Dec 03, 2013 11:59 AM
