This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Aug 19, 2004, 08:29 PM
Spadinator is offline
Find More Posts by Spadinator
Spad Builder/Basher
Spadinator's Avatar
Clinton,Utah
Joined May 2004
Here is my latest that I just finished today.....No stickers yet and it is built using JJ Carter's plan from Spadworld.net.
Spadinator is offline Find More Posts by Spadinator
Old Aug 20, 2004, 01:04 AM
jerry07_58 is offline
Find More Posts by jerry07_58
jerry07_58's Avatar
Maricopa, California
Joined Nov 2003
My Electric SPAD
jerry07_58 is offline Find More Posts by jerry07_58
Old Aug 20, 2004, 12:42 PM
Spadplanter is offline
Find More Posts by Spadplanter
I can TOO fly!
Spadplanter's Avatar
Southern Colorado
Joined Feb 2004
What power do you use?
I saw some pix in another thread where some fellow had covered the wing with solar cells! Infinite flight times.
(at least until crashed)
Spadplanter is offline Find More Posts by Spadplanter
Old Aug 20, 2004, 07:44 PM
mogley is offline
Find More Posts by mogley
Joined Dec 2003
Heres a couple I have built lately.
I used a plumbers pipe hanger on the qhor for a skid. Works great and it makes hanging the plane up a snap. All three planes use a bug juice botlle for a fuel tank, ( thank my 6 year old for them)! The BUHOR has a 68" wing span.
The plastic cup on the fuse is for the barbie paratroopers!!
mogley is offline Find More Posts by mogley
Old Aug 21, 2004, 12:51 AM
jerry07_58's Avatar
Joined Nov 2003
Spadplanter,
My Electric is powered by:
Kyosho Endoplasma 16 turn (truck motor)
GD600 gear box w/ 3.8:1 pinion gear
12 x 8 MAS electric prop
7 and 8 cell sub "C" 3300 mAh battery packs
everything is coroplast except for the wing. It is balsa w/ covering. I tried a coro wing but it was too heavy.
Jerry
Old Aug 21, 2004, 10:37 PM
I can TOO fly!
Southern Colorado
Joined Feb 2004
Would that be similar to a speed 600 motor? I need help crossing these motors over.
Old Aug 22, 2004, 03:37 AM
jerry07_58's Avatar
Joined Nov 2003
Spadplanter,
Yes it is equivelant. Here is the URL for this motor.
There is also a thread pertaining to this motor as well as the Hobbico Super Star EP and other electric planes weighing up to over 5 Lbs.
http://www2.towerhobbies.com/cgi-bin...&I=LXW933&P=ML
Hope this helps?
Jerry
Old Aug 22, 2004, 04:42 PM
I can TOO fly!
Southern Colorado
Joined Feb 2004
You bet! My Spectra has a speed 600 motor that is definitely on the wimpy side at 5600 feet. I'm ready to try almost anything!
Old Aug 22, 2004, 06:03 PM
jerry07_58's Avatar
Joined Nov 2003
Spadplanter,
I am no expert. But I should let you in on how to set this Endoplasma up for your Spectra.
Your going to have to upgrade this to a larger battery as well. I recommend the GP3300 mAh sub "C" battery. Most of us whom fly large electrics use this battery. Depending on the weight of your plane all depends on how many cells you ought to run in series.
Also you need to use a gear reduction gear box. Most of us use the GD600 gear box with a 3.8:1 pinion. This ensures enough RPM and helps to keep the amperage down so you don't burn out your ESC or motor.
As far as the prop size is concerned. I personally use a Master Aircrew Electric 12 x 8 and 11 x 8. If you look at the thread on the Super Star EP you'll see that most of us are in that general range of props. It all depends on what you want out of your plane.
Here is the URL for that thread.
http://www.rcgroups.com/forums/showt...1&page=1&pp=15
Old Aug 24, 2004, 09:29 PM
GaryMC1 is offline
Find More Posts by GaryMC1
Noob!
Norristown, PA
Joined Aug 2004
Originally Posted by balsabuster2004
Wufnu, thanks for the comments. I was wondering if anybody would go to the trouble of viewing my build slideshow. Thanks for taking the time.
Are you kidding? It was great. Since I know absolutely nothing about this stuff, I was amazed. I've seen this 'coroplast' before, but I'd never think that you could get it fly! And, on top of that, the finished product is a knock-out!
But, I do have to ask, how long did it take you to build the whole thing?
Amazing!
Gary
GaryMC1 is offline Find More Posts by GaryMC1
Old Aug 24, 2004, 10:12 PM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
GaryMC1
Gary,
Looking at the dates of the pictures, about 2 mo! However, I only worked on one piece at a time. I would glue a part together, set it aside for a day, waiting for the household goop to dry. Could have worked on the fuselage at the same time as the wing, but didn't. Didn't want to get confused. Sometimes, I would work several days in a row, then not do anything for several days. Manhours? No Idea. I added a picture to the slideshow at the end, today. (proof of flight)
Chuck.
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Sep 11, 2004, 06:16 PM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
I gotta say guys , you's are building some of the uggliest rc planes i've ever seen, keep up the good work... :O) Actually not the trainer in the above shot, as far as trainers go, that's a thing of beauty.
ClimaxPilot is offline Find More Posts by ClimaxPilot
Old Sep 11, 2004, 08:20 PM
Cdale03 is offline
Find More Posts by Cdale03
USA
Joined Sep 2004
Here is my first spad a V tail How do ya'll think its gonnsa fly.(OS 46 AX)
Cdale03 is offline Find More Posts by Cdale03
Old Sep 11, 2004, 10:40 PM
Chesty
Joined May 2003
SCARY !!!!
Old Sep 11, 2004, 10:41 PM
Chesty
Joined May 2003
SCARY !!!!
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
