This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Sep 11, 2012, 02:39 PM
Spaderman is offline
Find More Posts by Spaderman
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
I'll try, but a lot of work "feeling" and before I have to check that can fly!
1st flight Saturday and I make a video
Soon
fabrice
Spaderman is offline Find More Posts by Spaderman
Old Sep 11, 2012, 08:00 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
Originally Posted by Spaderman View Post
Hello all
The youngest.....
Soon a vidéo and more informations
Soon
fabrice
Awesome Craftsmanship!
Bravo Fabrice!
Mig Man is offline Find More Posts by Mig Man
Old Sep 23, 2012, 11:58 AM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Mugi derivative - 110mm span Avro Vulcan
My latest experiment - just seemed like an obvious evolution of the 150% Mugi. Have started a build log here: http://www.rcgroups.com/forums/showt...2#post22812021
Flight is stable and relaxing, with a nice turn of speed when throttled up.
Extreme Sports is offline Find More Posts by Extreme Sports
Old Oct 17, 2012, 05:34 AM
Joined May 2012
The Correx Funjet just became a Fastjet. See http://www.rcgroups.com/forums/showt...1727654&page=3
Old Dec 09, 2012, 01:27 PM
Spaderman's Avatar
Joined Mar 2010
Hello all
Just out of the "mold"
Wings 1200mm
Weight 1700grs
Engine .32 ASP
50% coro 50% polyester+fiber
the first flight of "Cortiss" P40
soon
Old Dec 22, 2012, 05:24 PM
robw_london is offline
Find More Posts by robw_london
Joined May 2012
Se5a
I thought I'd try a biplane. The SE5A has a slab-sided fuselage and parallel wings so its an easy shape. This one is all in 2mm correx with 3mm ply formers. span is 33 inches with 7 in cord (3.2 sq ft) and weight is spot on 32 oz so it has 10oz/sqft wing loading. Target was under 10 but its close enough!. motor is OS10la which should (just about?) manage it but I'm waiting on an 8x3 prob to make sure I get the thrust / rpm. There's .15 under the bench just in case...Wings are built thin (7/16 deep spar) and about 3 deg incidence. Now all I need is the weather - it driving rain and flood warnings here!
robw_london is offline Find More Posts by robw_london
Old Dec 22, 2012, 05:44 PM
Joined May 2012
I use 5mm ply for the firewall and 3 for the formers. Cut big holes in the formers. I use thick CA sold as mitre-kit in builders merchants with the kicker. Sand the correx to a slight fluff and put a 1/2 wide strip folded into an angle on the back once its in to act as a doubler. Plane in photo is 2mm wings, 4 mm fuse. Firewall is CA-ed in and holds a OS52 surpass no problems (photo shows OS 40FS but it was underpowered). This plane has now done hours of flights and is on its 3rd wing (pilot error!!) but firewall is still tight. Span is 55in and weight 73 oz and its a great flyer. Its modified from Beaver's Corofury.
Old Feb 11, 2013, 08:02 PM
Y.P.F. is offline
Find More Posts by Y.P.F.
Young Poor and Fun
United States, TX, Austin
Joined Sep 2012
That looks great.
Nice landing gear.
Y.P.F. is offline Find More Posts by Y.P.F.
Old Feb 12, 2013, 05:45 AM
Flying Beagle is online now
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
Black Spitfire
a few months ago I scored some 3mm black Correx off-cuts from a local packaging company. I had other "black" PSS intentions, but when my Camo Corrospit became a bit too abused from the Hermanus trip, I decided to build another Spitty
the wing at 3mm was only about a half ounce heavier than the Camo Spit's 2mm wing. I extended the nose about 20mm longer than my original (same as the plans on page 1) and was able to remove almost 150 grams from the original spinner. The Black Spitfire auw is 1100 grams
Spitfire LF Mk.IXe TE554, the Black Spitfire, former Israeli Air Force 20-57. The personal mount of former Israeli Air Force Chief of Staff and president Ezer Weizman
more info here
http://www.rcgroups.com/forums/showthread.php?t=1445391
Flying Beagle is online now Find More Posts by Flying Beagle
Old Feb 12, 2013, 10:58 PM
Mig Man is offline
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
Looking good there FB.
Old Mar 20, 2013, 03:50 PM
hutchinstuff is offline
Find More Posts by hutchinstuff
Hutch
hutchinstuff's Avatar
United States, Mt, Bozeman
Joined Jan 2012
The beginning of the fleet
Here are my 2 so far. The gnat and tweedle. Tweedle had a shorter wing and flew poorly. It's powered by twin ap 15s with optional thrust differential. The gnat has an xl 15
hutchinstuff is offline Find More Posts by hutchinstuff
Old Mar 20, 2013, 10:43 PM
Mig Man is offline
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
......... .......... ........... Did someone forget to attach the pics?
........I hate when that happens.
Old Mar 20, 2013, 10:48 PM
rockyabq is offline
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Nah, both planes are white. Kinda hard to see against the white clouds though.
rockyabq is offline Find More Posts by rockyabq
Old Mar 20, 2013, 11:08 PM
Hutch
Joined Jan 2012
Damn iPhone only lets me upload one photo! Here is the tweedle
Old Mar 29, 2013, 01:10 AM
Spaderman's Avatar
Joined Mar 2010
Hello all,
My youngest The "uglystang"....Sorry, the pun does not work in English ! :-(
In French "Mochestang"
Experimental construction with a "sandwich" coro 3mm /foam 50mm /coro 3mm
The unit is virtually indestructible !
Very easy to make and gives a finished fuselage with locations prepared for the radio, the tank and the engine mount in just 2 or 3 hours ...
But maybe someone with you tried?
I prepare a Mig 3 with the same concept, and I took pictures of the different stages
soon
fabrice
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 01:38 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
