This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Jul 11, 2012, 01:51 PM
gjmhughes is offline
Find More Posts by gjmhughes
Joined Jul 2012
here are the spads I have built.
Dogfighter - spad version of a Diamond Dust - and prob my fav The Sickle
Description:
Description:
Description:
gjmhughes is offline Find More Posts by gjmhughes
Old Jul 11, 2012, 02:01 PM
cr8tive_leo is offline
Find More Posts by cr8tive_leo
cr8tive_leo's Avatar
Canada, ON, Cochrane District
Joined Oct 2011
Love the Sickle!
Hmmmm... is there a build thread on that one? I tried spad to the bone.. but couldn't find it.. esily.
Thanks.
edit, found it after a bit of digging...
http://www.spadtothebone.net/SPAD/sickle/index.htm
cr8tive_leo is offline Find More Posts by cr8tive_leo
Old Jul 12, 2012, 06:25 AM
Spaderman is offline
Find More Posts by Spaderman
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
nice design
I like the graphic of the Sickle
Spaderman is offline Find More Posts by Spaderman
Old Jul 15, 2012, 01:12 AM
samlikespad is offline
Find More Posts by samlikespad
Jeddah
Joined Feb 2011
My CorroTwist .40 size
Built a Twist based on Waldo's tweplica and Forsty's VSF
Video:
SPAD CorroTwist Friday Flights (4 min 55 sec)
build thread is on spadworld.net : http://spadworld.net/forum/viewtopic...648&highlight=
and
http://www.rcindia.org/electric-plan...twist-40-size/
samlikespad is offline Find More Posts by samlikespad
Old Aug 12, 2012, 09:34 PM
scrubmonkey is offline
Find More Posts by scrubmonkey
Australia, QLD, Booyal
Joined Aug 2011
Ive got a general a few generalquestions before i start my first build
1) how is the firewall attarched to the plane usually (corocub from sttb)
2) what is the usual glue used
3) with the corocub are the wing tips and tail free handed
4) is it alright to use 4mm corflute all round
5) is square down pipe readily availabe in australia usually
6) if not what is a good substitute
Looking foward to start building
scrubmonkey is offline Find More Posts by scrubmonkey
Old Aug 13, 2012, 01:48 AM
flymess is offline
Find More Posts by flymess
Corflute Codger
flymess's Avatar
Australia, New South Wales, Fernmount
Joined Feb 2011
Scrub,
You don't have to follow the SPAD directions too closely. We don't seem to have the gutter pipe that they use in USA but you can make your own square pipe out of the corflute. Don't know where you are getting your 4mm corflute because most stuff I get is 3mm or 5mm. Use the smallest you can get for the wings and the thick stuff for the fuse. Either one for the elevator and rudder.
I use a hot glue gun to stick mine together mostly but it has limits. good for "butt joints" ie sticking things together at an angle eg 90*, but not good for gluing flat on flat. I suggest you poke little holes into the corflute where you want to glue it together as this gives it a good hold. Epoxy resin, like Araldite should work OK too. Also you can hold some things together with small cable ties which is a lot easier than glue and allows you to cut them open if you need to. I have built great flying wings using this method. Hope you have fun with your build
flymess is offline Find More Posts by flymess
Old Aug 13, 2012, 02:02 AM
Joined Aug 2011
Well how do you attatch the fire wall then? Dad used to work as a bulder and i have a two foot high pile of the stuff. I pretty sure it is 4mm but it might be 5. Close enough any way. Would araldite work? I mix it on ice cream lids because it doesnt stick to the plastic. I used hot glue hor the airboat which is still yet to go so yeah.
Old Aug 13, 2012, 02:12 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
I make pusher jets mostly so no firewall needed. but when i have used firewalls i glued two pieces of thin plywood together and cut it to fit inside the nose of the fuse. Then just screw it in from outside the fuse with a few wood screws. There are probably lots of other ways to do it. Look around the forum and you'll find lots of good ideas
If the glue doesn't stick to plastic remember to poke some small holes in the corflute and it will hold a lot better
Old Aug 13, 2012, 02:17 AM
Joined Aug 2011
This is with a 60 size glow engine. So no electric. And if thats all thats needed i better grab some from the shed next time we drive past.
Old Aug 13, 2012, 02:36 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
you should look for more info about firewalls because I only know about electric and they don't weigh much
Old Aug 13, 2012, 08:38 AM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
Originally Posted by Spaderman View Post
Hello all
The last construction of a member of our club
Wingspan 1400mm
Weight + - 2 Kgs
Engine .46
Little vidéo
soon
fabrice
love to have more details about this plane. does it fly OK?
any chance of getting some plans please?
Old Aug 13, 2012, 11:11 AM
Flying Beagle is online now
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
Originally Posted by samlikespad View Post
Finished her up and all set for maiden
Sam
Your Edge looks great. Are plans available ?
Flying Beagle is online now Find More Posts by Flying Beagle
Old Aug 14, 2012, 05:45 AM
Blizards316 is offline
Find More Posts by Blizards316
Glow? What is that?
South Africa, GP, Pretoria
Joined Apr 2009
Here is a few of my SPADS...
Blizards316 is offline Find More Posts by Blizards316
Old Aug 19, 2012, 04:55 PM
flymess is offline
Corflute Codger
flymess's Avatar
Joined Feb 2011
simplest SPAD
I'm going for the simplest PAD ever. 1 sheet of corro 900mm x 600mm. 60* angle bend, basically an equilateral triangle with a motor. Work in progress but I expect it to go
Old Aug 23, 2012, 09:47 AM
RayInFlight is offline
Find More Posts by RayInFlight
Beginner Flyer
Singapore, Singapore
Joined Jul 2012
my first SPAD
this is my first SPAD and also my first build. slow flying.
RayInFlight is offline Find More Posts by RayInFlight
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
