This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Feb 04, 2012, 08:04 PM
Corocrumpler is offline
Find More Posts by Corocrumpler
Watch This!
Corocrumpler's Avatar
United States, LA, Washington
Joined Feb 2007
Hey Stretch1
The wing on your Funda is a KFM3, are you pretty happy with its performance? I just recently built a wing with a KFM2 and it flies better than I expected. FKM's save a lot of weight on the TE since they are single layers, and with coro the weight adds up fast.
Corocrumpler is offline Find More Posts by Corocrumpler
Old Feb 05, 2012, 04:02 PM
Stretch1 is offline
Find More Posts by Stretch1
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
Originally Posted by Corocrumpler View Post
Hey Stretch1
G'day Corocrumpler,
It's actually closer a KFM4 , except that the step is at a bit over a third of chord rather than a half, and it's not really a true KF step as the trailing edge of the step is the same height as the leading edge. I've built a couple of foamies with a KFM1 styled foil and they seemed to fly pretty well. ( There are plenty of pics in my blog.)
I've used posterboard foam for the top and bottom steps on this wing to keep the weight down. (4mm coro for the wing and 'fuse', 2mm with bamboo inserts for the vertical stabilisers) There's a carbon arrow shaft along the leading edge as well.
I wanted to build a simple airframe that wouldn't flex under high speed loads.
( I'd eventually like to end up with something I can bolt my 1200W funjet running gear into.)
Stretch1 is offline Find More Posts by Stretch1
Old Feb 06, 2012, 11:18 AM
Watch This!
Joined Feb 2007
Stretch1,
You are correct, I had my KFM3 and KFM4 confused. The foam is an interesting way of creating a step without adding a lot of weight, and works well. Please post a video when you fly a new plane with the 1200 watt set up, that is a lot of juice! I also use carbon fiber arrow shafts, as main spars, sometimes I bundle them and screw the ends together to get a long enough spar. They work well and are readily available.
Old Feb 06, 2012, 01:45 PM
Spaderman is offline
Find More Posts by Spaderman
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
Hello all
My last
1.34m
os .40
électric rétract
2.5kg
soon
Spaderman is offline Find More Posts by Spaderman
Old Feb 06, 2012, 11:41 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
Originally Posted by Spaderman View Post
Hello all
My last
1.34m
os .40
électric rétract
2.5kg
soon
That is amazing. You have talent spaderman!!!!!!!!
Kyler1 is offline Find More Posts by Kyler1
Old Feb 07, 2012, 02:18 AM
Spaderman's Avatar
Joined Mar 2010
Thank you
My next construction .....Corsair-toon
0.68m
engine .21
+-1kg
Propeler 3 blades 8x6
Sorry for my bad English
Soon
fabrice
Old Feb 07, 2012, 10:06 AM
pichuete is offline
Find More Posts by pichuete
Joined Feb 2011
nice Mig Spaderman. can you post a pics how did you adapt the retracts to the wing. im planing to put some wheels on my A-10 .
but im not sure how to reinforce it the wing is already Made
pichuete is offline Find More Posts by pichuete
Old Feb 07, 2012, 12:08 PM
Spaderman's Avatar
Joined Mar 2010
Hello,
Simply fixed on the member of the wings, and a reinforcement stuck on the coro
Drawing of design
Soon
Old Feb 07, 2012, 01:12 PM
pichuete is offline
Joined Feb 2011
thanks for your reply ... ill see what i can do. the thing is that i make the main spar from balsa to keep weight down.. (still very strong) but . balsa doesnt like to put screws in it. it will weak the wood and strip it.....
but i got the idea thanks!
Old Feb 07, 2012, 01:46 PM
MrClean is offline
Find More Posts by MrClean
Somewhere near Parkville, Mo.
Joined May 2004
To reinforce, and I know you're trying to keep weight down so I don't know how much this would weigh, you can make your own filler junk out of Silicone and Corn Starch. Glue your light ply or hardwood mounting plates in place. Cover your retract parts with a balloon. HUH??? All the old FF guys will just say ok. Partially blow a balloon up, press your part into the side of the balloon opposite of the stem and as you get the item into the balloon start letting the air out of the balloon. Smooth out the rubber of the balloon. Mix up the Silicone/corn starch and press it into place in the wing between the upper and lower skin and press your part into place. You're looking to displace any goop in the area under the retract mechanism. Let it setup and pull your part back out, remove the balloon and you should be able to mount the retract into a section of wing that is solid. Don't know how heavy it will be yet. You could use Micro Balloons. I don't know how much lighter that would be. Here is the link to the above goops webpage on the Instructables website.
Should make it solid at least.
MrClean is offline Find More Posts by MrClean
Old Feb 08, 2012, 09:19 AM
draftman1 is offline
Find More Posts by draftman1
draftman1's Avatar
central CA
Joined Aug 2002
Thank you
0.68m
engine .21
+-1kg
Soon
fabrice
awesome spaderman!! I see you have been watching the build videos!
good luck on the maiden!
draftman1 is offline Find More Posts by draftman1
Old Feb 08, 2012, 02:41 PM
Spaderman's Avatar
Joined Mar 2010
Hello Draftman
Indeed,
much of interesting things on the vidéos.
I to put the link on our Forum
spad-mania
Soon
Fabrice
Old Feb 09, 2012, 07:49 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
Hello all
My last
1.34m
os .40
électric rétract
2.5kg
soon
Hi Spaderman. Good to see you were able to get a Mig built! Sorry I could not have been of more help with a kit when you asked a few years back.
It looks real nice, I'm impressed with the retracts. I tried unsuccessfully to put landing gear on the scale Mig 7 but gave up because it just didn't work. (for me anyway) Glad you had success.
Looks Nice!
Mig Man is offline Find More Posts by Mig Man
Old Feb 10, 2012, 02:08 AM
Spaderman's Avatar
Joined Mar 2010
Hello guys
Mig and Spit with the original size
spit vidéo
the fighter of my last season of combat
wings 1.00m
engine .32
weight 1.2kg
soon
fabrice
Old Feb 10, 2012, 06:26 AM
Spaderman's Avatar
Joined Mar 2010
Hello guys
My "french" version of Gnat, just for fun or the recreation, a small size for the holidays
wings 0.80m
engine .12 / .15
weight +-750 grs
Joke plan
Joke vidéo
Soon
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 02:38 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 06:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 07:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 08, 2002 12:00 AM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 02:51 PM
