This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Apr 27, 2006, 10:22 AM
balsabuster2004 is offline
Find More Posts by balsabuster2004
balsabuster2004's Avatar
Washougal, Washington, United States
Joined Jan 2004
Tree
Flew my Spadet LC-40 through a tree. Broke 2 rubber bands and put a small dent in the leading edge of the wing. Balsa? Would have had to use a garbage bag to collect all the pieces.
balsabuster2004 is offline Find More Posts by balsabuster2004
Old Apr 27, 2006, 01:23 PM
omaha_rc_flyer is offline
Find More Posts by omaha_rc_flyer
omaha_rc_flyer's Avatar
Omaha, Nebraska
Here is my latest Project.
Well I have been working on my ML Spattern for almost a year now and it is almost finished. Attached are a few pictures. You can read more about it and see more detail here
omaha_rc_flyer is offline Find More Posts by omaha_rc_flyer
Old Apr 28, 2006, 05:37 AM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
I hate those days when a bag is the easiest thing to carry your planes home ( or the bin) in. ???????????When is a SPAD no longer a spad????????????
Desert flier is offline Find More Posts by Desert flier
Old Apr 28, 2006, 08:45 PM
JWarren is offline
Find More Posts by JWarren
Just one more plane!
JWarren's Avatar
Port Saint Lucie, Florida, United States
Joined Aug 2004
That's a good question Desert!
When the glue just won't stick anymore?
Nice SPAD Omaha!
John
JWarren is offline Find More Posts by JWarren
Old Apr 29, 2006, 09:59 AM
Omaha, Nebraska
JWarren,
Thanks!
Later,
Omaha
Old Apr 29, 2006, 05:46 PM
nice SPAD keep us informed how it flies did you use an online plan or build by eye?
Old Apr 29, 2006, 08:02 PM
Omaha, Nebraska
Thanks Desert flier!
I designed and built it a little by eye or by the TLAR theory (That Looks About Right), but mostly from spad building experience, crunching numbers and using design tools such as wing calculators etc...
If she flies well, I will finish the plans I have started and hopefully get them hosted at www.spadtothebone.com
Later,
Omaha
Old Apr 30, 2006, 11:30 AM
Smooth Spanky is offline
Find More Posts by Smooth Spanky
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
Omaha:
I think for your plane the normal SPAD definition should be refined to: Superb Plastic Airplane Design.
Good luck withe plane...would love to see some plans!!
SS
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Apr 30, 2006, 12:45 PM
Omaha, Nebraska
SS,
Thanks for the compliment!!
The "Simple" should be taken out of it, for sure. Maybe something like "Scary", "Stressful", "Stretched out" or "Strenuous".
This is not one for a new spad builder to cut his or her teeth on. Not to say it couldn't be done, but I would suggest building a few original spads first, before tackling a build like this.
Later,
Omaha
Old May 01, 2006, 03:47 AM
Is this a PAD ( Plastic Aircraft Design)
????????When is a SPAD not a spad????????? When it takes two or thre weeks to build maybe!!!!!!
Old May 15, 2006, 04:24 AM
Main spar failure
Here is a pic of my spad after a mainspar failure Had just been practicing circuits and decided to do a few loops had just completed a few gentle loops and flying level when the wing sparr gave away and the rest is history. the next spar will have fibre glass wraped around the centre join.
Old May 15, 2006, 10:04 PM
Detroit, Michigan
Desert Flier:
Sorry to hear about the mishap. Looks like all the vital equipment is still in good shape.
It's hard to tell from the photo, but did your spars fail by rotating about the center piece of carbon? If so, perhaps using two side-by-side pieces would eliminate the pivot point. For what it's worth...
Good luck.
SS
Old May 16, 2006, 05:19 AM
The spar had doublers glued to the front and back with a spacer glued on the front the carbon rods were used as pins to hold the front of the wing to the fuse. I only used woodwork CA glue and scrathed the varnish to roughen it up mark 2 will have the varnish completly removes and epoxy glue for the jint with fiberglass wraped around the joint. I am a beginer at power flying the most stress comes from landing ( ariving ) not from load in the air. The joint came apart in a previous spin in and I squirted glue into the jount and clamped it this probably was a waRNING sighn that i missed.
Old Sep 19, 2006, 08:06 PM
motohead is offline
Find More Posts by motohead
Joined Jul 2005
Own design Low Wing
Here's my latest design. Flies great. 54in WS. 50in Length. Weight is 5.8lbs. Flying it with a new SK 50A. Here's a vid link.
http://savefile.com/projects/1015997
motohead
motohead is offline Find More Posts by motohead
Old Sep 21, 2006, 12:21 PM
Zimodile is offline
Find More Posts by Zimodile
Leicestershire
Joined Sep 2006
Originally Posted by balsabuster2004
Wufnu, thanks for the comments. I was wondering if anybody would go to the trouble of viewing my build slideshow. Thanks for taking the time.
Hey Balsa - great design - like the build slideshow too - I'm getting to do my first spad shortly (materials on order) and it was very instructive...
Zimodile...
Zimodile is offline Find More Posts by Zimodile
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
