This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Apr 16, 2004, 09:04 PM
Spadplanter is offline
Find More Posts by Spadplanter
I can TOO fly!
Spadplanter's Avatar
Southern Colorado
Joined Feb 2004
Cool
Let's see the S.P.A.Ds
Lets see the SPADs that have been built.
I'll start.
It's survived several accidental landings!
Spadplanter is offline Find More Posts by Spadplanter
Old Apr 17, 2004, 10:20 PM
mosquitowings is offline
Find More Posts by mosquitowings
mosquitowings's Avatar
United States, OK, Bethany
Joined Feb 2004
This is my first SPAD, it's an L-19 from fly r/c mag plans enlarged 400*/*
ASP 52 fs for power, 5ch w/ flaps. If your going to try something new, why not shoot the moon?
Jim
mosquitowings is offline Find More Posts by mosquitowings
Old Apr 18, 2004, 09:49 AM
JimRoss is offline
Find More Posts by JimRoss
Just a Great Guy!
Humble, Texas
Joined Jan 2004
Spads
Here's mine so far. Working on a Weevil for fun and a Deb for club trainer.
JimRoss is offline Find More Posts by JimRoss
Old Apr 20, 2004, 05:06 AM
TLAR is offline
Find More Posts by TLAR
Spadder
TLAR's Avatar
Kansas
Joined Aug 2003
Here's an old pic of Debby #2. She was always one of my favorite airplanes
TLAR is offline Find More Posts by TLAR
Old Apr 21, 2004, 09:52 PM
JimRoss is offline
Just a Great Guy!
Humble, Texas
Joined Jan 2004
New Weevil
Ok, here's the newest addition to my spad gallery. The Weevil Lives.
BTW, the canopy is not part of the plans. I did that because I don't like flat tops.
Old Apr 21, 2004, 09:59 PM
Joined Feb 2004
Jim that wevil looks like a handful, what size motor is that?
Old Apr 22, 2004, 08:33 AM
JimRoss is offline
Just a Great Guy!
Humble, Texas
Joined Jan 2004
Weevil
It really isn't at all. If you can fly solo and have any confidence at all you will do great with it. Only caution is to set control surfaces to about 50% of max throws to start with until you get a few flights on it and see what you can handle. After that, GO NUTS!
Believe it or not, it flies rather docile in level flight and gentle turns but it is VERY responsive to pitch changes so be careful.
My first flight, it took off by itself. Had a little UP trim in elevons and POW, it lifted right off. Easily fixed though, down trim made it fly level. Landing her was the difficult part. Symmetrical wing made it drop like a rock with power off. Keep some throttle in it until just before touch down. IOW, Fly it in to landing.
It was really windy yesterday so the flights were more work than fun but hopefully it will calm down this weekend and I can try her again.
I have an OS 48 Four Stroke on it right now but I don't like the minimal power available from it. Got a GMS 47 I'm gonna put on it and then she should really root and scoot. A friend had one at the field yesterday with a Thunder Tiger Pro 46 on it with a Tower 46 Tuned Muffler and I saw it tach 15,000 rpm. Now that one really honked. Go ahead and build one for yourself, they are easy to build and nearly foolproof. You go by the plans and I promise it will fly and you'll like it. One thing nice about these spads, the plans and designs are already proven to work so this is not something unknown.
Besides that you can make one for under $20.00. What other plane can you build that inexpensively?
Old Apr 27, 2004, 12:31 PM
ErnieR is offline
Find More Posts by ErnieR
Haverhill, MA
Joined Jul 2000
ErnieR is offline Find More Posts by ErnieR
Old Apr 29, 2004, 12:15 PM
I can TOO fly!
Southern Colorado
Joined Feb 2004
Is that a Hula Hoop????
Old Apr 29, 2004, 01:33 PM
ErnieR is offline
Haverhill, MA
Joined Jul 2000
Ist das nicht ein hula hoop? Ja, das ist ein hula hoop.
It's one of those things that you get in your head and you just have to try. Yes, it does fly.
See this thread- http://spadworld.net/viewtopic.php?t=7766
(Sorry for the bad German)
Old Apr 29, 2004, 01:46 PM
I can TOO fly!
Southern Colorado
Joined Feb 2004
I like the idea that when you go straight in, the motor's protected.
How do you launch it?
Old Apr 30, 2004, 08:24 AM
ErnieR is offline
Haverhill, MA
Joined Jul 2000
To launch it I hold onto the fuel tank, which is on the CG, point the nose up a little, crank her up to full throttle and just let go. The plane takes right off. Landing it is a little more difficult as it floats about the same as a brick. I have to fly it to about a foot or two off the ground and cut the engine and let it flop down.
Old May 03, 2004, 11:19 PM
rfgty98 is offline
Find More Posts by rfgty98
Joined Oct 2003
My Montana trainer, Plans from "Benjammin". Basically a Deb with closed wings and a flipped over fuse. This thing fly great and just floats in for landings either rubber side up or cartwheeled. One tough plane, only a broken fuse, (repaired in an hour) and firewall. Use HPD for firewall not ply, the ply will shear along the laminations due to the screws. All 4 mil coro and American gutter pipe, Mecoa .46 on 10x6. Needs a bigger tank, gonna try a babies bottle instead. Also have a DPS but no pics just yet,
rfgty98 is offline Find More Posts by rfgty98
Old May 04, 2004, 11:21 PM
globemaster3c17 is offline
Find More Posts by globemaster3c17
Calm winds and CAVU skies
globemaster3c17's Avatar
Lawton, OK
Joined Jan 2004
What is HPD that you used for your firewall?
globemaster3c17 is offline Find More Posts by globemaster3c17
Old May 05, 2004, 01:41 AM
rfgty98 is offline
Joined Oct 2003
The HPD or is it HDP any way, it is poly cutting board like the kind you use in the kitchen. Get it at wall mart, one board is enough to make several firewalls. The set screws for the motor mount and for the firewall will not pull out and it is already fuel proof. The poly board will not separate like ply can either. If you have a table saw cut a step in it with the inside and outside dimensions of your pipe, this will be even stronger. There is a place on the web "Coroplast Building Ideas" that sells them pre cut for a few bucks.
Good luck
Doug
Gallery Let's see your boats flailing Scale Boats 350 May 26, 2016 07:47 AM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 05:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 06:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 07, 2002 11:00 PM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 01:51 PM
