Old Apr 16, 2004, 08:29 PM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Poppy with it's new LED setup
Here's my Poppy with it's new LED light setup installed. Thanks again to Mike Connally for his invaluable help on my first setup. So that's what the letter "K" on the resistor package means.... I only hope the wind dies down here soon!
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Apr 16, 2004, 08:36 PM
Mikey C. is offline
Find More Posts by Mikey C.
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
looks good! I especially like the "headlight".
-Mike
Mikey C. is offline Find More Posts by Mikey C.
Old Apr 16, 2004, 09:32 PM
furnaceman is offline
Find More Posts by furnaceman
furnaceman's Avatar
Syracuse Hancock, New York, United States
Joined Mar 2004
I have started my led stuff here is a pic of the tail. i chose to have the light up th plane and not shine out too much so i can see it more
Bill
furnaceman is offline Find More Posts by furnaceman
Old Apr 17, 2004, 07:27 AM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Thanks, Mike! That's "Taz" at the controls. It's got a GWS "A" drive with an 8X6 prop instead of the stock 480 motor, which takes almost 3 oz. off of the weight. Here's a brighter picture. Furnaceman, the LED on the side looks good! Is that a GWS E-Starter?
Ronnie
Old Apr 17, 2004, 09:14 AM
furnaceman's Avatar
Joined Mar 2004
YEs that is my e starter love that plane realy good all around flyer!
Old Apr 23, 2004, 08:44 AM
MichaelConnally is offline
Find More Posts by MichaelConnally
flutter!
MichaelConnally's Avatar
TX
Joined Jul 2002
It should be said that the poppy has a 370 or 350 A drive not an ips.
MichaelConnally is offline Find More Posts by MichaelConnally
Old Apr 23, 2004, 09:54 AM
Ducman69 is offline
Find More Posts by Ducman69
I'm big in Japan
Ducman69's Avatar
Houston, TX
Joined Feb 2004
I hope to be doing this soon too, except I want to try and make a removable "disco ball" with a deans connector.
I have a GWS Slow stick and wanted to make a mount with a foam disco ball suspended under the plane. The disco ball would have several LEDs mounted in it with four front facing 1000mcd white LEDs, two diffused LEDs pointing up lighting the bottom of the wings (in different colors for orientation) and then two pointing back to light up the tail feathers.
The advantage is that it should light up the plane rather than just looking at the LEDs and its easily removable for day-time flight, but hte disadvantage is that its only lighting up the bottom surface well. I think there would be enough bleed and spillover of the light that it could be viewed even in a high bank turn w/o issue.
Ducman69 is offline Find More Posts by Ducman69
Old Apr 23, 2004, 10:01 AM
flutter!
TX
Joined Jul 2002
That sounds really cool...It needs it's own power supply so it can be dropped as a night bomb
Old Apr 23, 2004, 01:16 PM
wallasan10 is offline
Find More Posts by wallasan10
wallasan10's Avatar
United States of Texas
Joined Dec 2001
My slow stick hanging from the ceiling. No disco ball tho. And I did end up adding red leds to the top of each wing tip.
Its as eazy to see at night as in daylight, maybe more so.
Allons, Randy
p.s. cowtown usa= Fort Worth?
wallasan10 is offline Find More Posts by wallasan10
Old Apr 23, 2004, 01:37 PM
flutter!
TX
Joined Jul 2002
How about this for a light system? This is my EAM Strike.
Old Apr 23, 2004, 02:35 PM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Wallasan10,
Yes sir! I'm actually in Watauga, north of Fort Worth.
Ronnie
Old Apr 23, 2004, 04:02 PM
Ducman69 is offline
I'm big in Japan
Ducman69's Avatar
Houston, TX
Joined Feb 2004
HAHA!
Sweeet! Checkout that bomb!
Where did the plane go? *scratching head*
How's my setup with my New Hummingbird Elite Dan_eflyer Micro Helis 18 Sep 03, 2004 12:39 PM
Help with a S-400setup for a new guy and a Shrike! caleb High Performance 2 Nov 20, 2002 07:45 PM
F/S Wattage Super Cobalt 400 27T motor with adapter New RCFLYER0001 Aircraft - Electric - Airplanes (FS/W) 3 Sep 08, 2002 08:59 AM
Need help with my new Lion's gobigdale Parkflyers 12 Aug 19, 2002 09:18 PM
F/S New hornet built with CP head logo10 Aircraft - Electric - Airplanes (FS/W) 0 May 20, 2002 01:07 AM
