Old Apr 16, 2004, 10:39 AM
Joined Apr 2004
Nitro Hammer
I just recently got a hobbico(aquacraft) nitro hammer second hand. I am having some problems getting the engine to run right. Could some one help me with it? First is the needles, what are the factory settings or how should the idel mixture need look like at wide open throttle. once it starts, it bogs down with you give it full throttle. IT also sometimes at idle will race really high even though the throttle does not move. Also the tabs on the back, do you bend them up to ride higher out of the water, or opposite? Also what are some good mods you all would recommend to it? Thanks guys. I would greatly appreciate it if you could help me.
MattBar313 is offline Find More Posts by MattBar313
Old Apr 16, 2004, 11:37 AM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Well, I can help you with the tabs. They are called treim tabs.
If you bend them up, the nose of the boat will ride higher.
The idea is, if the bow of the boat is "porposiing" or bouncing up and down, you will want to bend those tabs down(evenly) till the bow of the boat stops porposing and boat drives smoothly across the water.
As for engine tuning most engines, as I recall, seem to like to start out at about 3 and a half turns from fully closed. Then the motor is tuned to a nice high pitch at full throttle. I have no other idea how to describe it. There are also set screws that will set the max and minimum throttle on some engines.
I hope you can get more help than mine on the engine settings.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Apr 16, 2004, 02:08 PM
Joined Apr 2004
thanks umi. is that 3 turns from closed on the idle mixture needle?
Old Apr 16, 2004, 03:20 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
It sounds like it is running too lean. The high revs at idle is the clue and bogging down in the water. boats have to be run slightly rich on the land then when they are put in the water, the load of the prop will lean the motor out. This can and will change day-by-day and sometimes in a few hours.
Thanks Umi for turning me onto this site.
Ron Olson is offline Find More Posts by Ron Olson
Old Apr 17, 2004, 03:02 PM
Joined Apr 2004
hey guys thanks for the help. I have some more questions. How many shims should be under the cooling jacket? I had 3, is that to many? Also it seems like it is not sealing. I have my boat sit for a night and there is an oily residue all over the engine and hull the next morning. I did have some fuel in the fuel tank, but I don't know what is leaking.
Old Apr 17, 2004, 03:31 PM
Joined Apr 2004
one more question. i took off my cooling jacket, and it came in two pieces. What should I use to seel the two back together? Is there a gasket or use some kind of automotive sealer? Thanks.
Old Aug 13, 2004, 11:55 PM
911Dispatch's Avatar
Kokomo, IN
Joined Aug 2004
There is no cooling jacket on the Nitro Hammer, is there?
My Hammer's idle mixture screw is about 1.5 turns from closed. My high-speed needle valve is set about 2 turns from closed now. The manual and video says to set the high speed needle valve 2.5 to 3 turns out from closed then lean it out till it's tuned and leave the idle screw alone. You can download the original manual here:
http://www.aquacraftmodels.com/downloads.html
If your boat is second hand I imagine it's already broken-in, maybe not correctly though. You'll have to play it by ear until you get the hang of it, also try turning the high-speed needle valve (left side of the carb), counterclockwise a little at a time until the engine doesn't bog down when you hit the throttle.
911Dispatch is offline Find More Posts by 911Dispatch
Old Sep 05, 2007, 01:35 AM
Joined Sep 2007
on my cd thay start the boat with out it raceing really high.
I fixed this bye ajusting the link on the carby so it would close more and now it doesnt race as you say.
Originally Posted by MattBar313
I just recently got a hobbico(aquacraft) nitro hammer second hand. I am having some problems getting the engine to run right. Could some one help me with it? First is the needles, what are the factory settings or how should the idel mixture need look like at wide open throttle. once it starts, it bogs down with you give it full throttle. . Also the tabs on the back, do you bend them up to ride higher out of the water, or opposite? Also what are some good mods you all would recommend to it? Thanks guys. I would greatly appreciate it if you could help me.
rocketwheels is offline Find More Posts by rocketwheels
Old Aug 29, 2008, 07:25 AM
Joined Mar 2006
I´we made some mods on my nitro hammer, i changed the rudder to a CNC cutt aluminium one with built in water pick-up, changed the power switch for the radio to one that´s water proff, changed the mount for the antenna to one that´s more stable and water proff and i drilled two holes in the deck to give the engine more air.
I´m wery pleased with my nitro hammer after these mods, especially the rudder since the original one is crapp and brokes WERY easily.
Somemore mods are on hte way, an octyra berylium propp, new 4mm propp shaft with M4 threads (standard are 4mm with M3threads), a better exhaust pipe and maybe a .18-.19 engine.
Here´s a shortmovie clip of my nitro hammer before the mods
Running my aquacraft nitro hammer 2 (0 min 26 sec)
.PS. I hade some problems with the engine thats simillar to the ones that you describe butt it was the low-speed needle that needed some adjusting.
slow_nisse is offline Find More Posts by slow_nisse
Old Sep 14, 2008, 04:13 PM
Joined Mar 2006
Does enyone think this propp shaft angle mod will do any speed improvement?
A good tip for the nitro hammer is to cut a hole in the hatch just above the main carb needle, it make adjustment so much easier.
more speed for my Nitro Hammer Cknoma Racing Boats - Internal Combustion 10 Nov 04, 2009 09:11 AM
FS - Hobbico AquaCraft Nitro Hammer GP RTR Dynomike Boats (FS/W) 0 Dec 09, 2004 12:10 AM
Nitro Hammer engine swap MattBar313 Dock Talk 9 Aug 16, 2004 04:56 PM
question about nitro hammer.. RG501 Racing Boats - Internal Combustion 2 Jun 27, 2004 11:33 AM
nitro hammer help fastnitro Racing Boats - Internal Combustion 7 May 25, 2004 04:50 AM
